Just moved and reinstalled Culligan Mark 100 and Have Some Resin in Backwash
Discussion in 'Water Softener Forum, problems, installation and r' started by jkmason, Jun 30, 2010.
  1. jkmason
    jkmason New Member
    Jan 8, 2009
    Minnesota
    I just retired my old Culligan Mark 59 Aqua Sensor which I have had since 1984. I replaced it with a used Mark 100. I picked it up across town and transported it to my home about 35 Miles laying down in my backseat.
    After installation, I ran a manual regeneration cycle. I noticed a lot of flakes (rust colored) and I think some resin; a very fine gritty sandy material coming out the discharge tube. I've never handled resin, so I don't really know what it looks like.
    Anyway, it is hooked up correctly; in is in and out is out. The amount of material coming out is very sparse and it appears to have diminished during the second regeneration cycle. So, is this normal? Anything I should watch out for or any corrective action to take. Thanks for any replies! Jack
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Sounds like you just turned on the water full and started it into a back wash , with the air that is in there there is going to be some resin blown out of the unit.
    Look for high level in the brine tank , or no brine usage... injector plugged, look for water to the drain when it should be in service, sign that there is some thing in the main piston that should not be and letting water go to the drain.
  4. Gary Slusser
    Retired
    That is due to laying it down and getting resin up in the control valve. But if it continues, then you have something else wrong, like a broken distributor tube; which could lead to resin in your plumbing or hard water.
  5. jkmason
    jkmason New Member
    Jan 8, 2009
    Minnesota
    Thank you so much for the advice and help. I initiated another regeneration and noticed a very tiny bit of resin during the tail end of the cycle. I held my hand under the hose outlet. It couldn't ahve been more than 1/2 teaspoon. The unit sucked up the brine just fine and then did the final flush. I think I'm good to go. I hope so anyway. Thanks again, jack
  6. Gary Slusser
    Retired
    You may have higher water pressure than the location the softener was used in before and then this is normal for a softener without a top basket. If that is the case, then this will stop soon.
Similar Threads: moved reinstalled
Water Softener Forum, problems, installation and r Bacteria after clorine has been removed? Jan 30, 2014
Water Softener Forum, problems, installation and r Calling all water quality experts for recommendations. - moved form pumps and tanks May 15, 2013
Water Softener Forum, problems, installation and r Removed a water softener system Jan 15, 2010
