Just had well installed...sprinklers won't stop!!!
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by iPhoneSRQ, Apr 16, 2009.
  1. iPhoneSRQ
    iPhoneSRQ New Member
    Apr 16, 2009
    Hello, I just had a 180' 4" well dug & installed by a company. I have a submersible pump & a pressure tank (bladder type I think). The well is for irrigation purposes only.
    The company left my property & my sprinklers started by themselves??
    I checked the sprinkler timer & it was off as I expected...the sprinkers are actually on in 1 & partially 2 different zones. It sounds like the pressure tank gets kicked on & won't shut off till I throw the breaker.
    Also I live in FL so I guess 180' is sufficient...they said the pump is submersed to 70' does this sound correct?
    thanks for the help
  2. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    Are there electric solenoids for each zone? It sound like they may not be wired right or not working at all.
    Something has to turn the sprinklers on and off.
    If the zone controller was not setup right, can cause false signals to the solenoids.
    Just a thought.
    Travis
  4. iPhoneSRQ
    Apr 16, 2009
    the sprinker system was set up & working fine before the well was put in... have 4 zones, but I don't know where valves with the electric solenoids are located...
    Is there an easy way to locate these valves w/ solenoids? because we had sod put down and now these have been covered up with sod...oooops!
  5. Waterwelldude
    Feb 11, 2009
    Texas
    Was the power turned off the sprinkler system controller? It may just need to be reset.
    I was going to say, the solenoids should be located in the yard. You pretty much covered that aspect of it..lol :)
    The easiest way I can think of is to use a medal detector. They should be located in some type of plastic box buried in the ground.
    Travis
  6. iPhoneSRQ
    Apr 16, 2009
    nah, the power was to the sprinkler timer & they were still running...so I'm thinking must have to find these valves and inspect.
  7. hj
    sprinkler
    Something must have gotten into the valves and prevents them from closing. WHO in his right mind buries sprinkler valves? I suppose the answer to that question is that it is the same person who buries/covers outdoor sewer cleanouts.
  8. iPhoneSRQ
    Apr 16, 2009
    WHo in their mind....I know I called the landscape guy today & gave him a word or two!!
    Sorry I'm new, so how do I clean the valves?? I did locate them (cost me $60 to pay a pro to find them)
  9. iPhoneSRQ
    Apr 16, 2009
    The $60 was to use machine that locates valves, not cleaning....I will try cleaning.
    Thank you
Similar Threads: installedsprinklers won't
Pumps and Tanks Well Forum & Blog. Water is life. Well pump pressure switch won't engage Mar 18, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Generator won't run well pump Jan 31, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well pump won't build up pressure Aug 23, 2015
Pumps and Tanks Well Forum & Blog. Water is life. pressure switch won't stay on water keeps shutting off in house Aug 8, 2015
