just did reline, need your professional advice
Discussion in 'HVAC Heating & Cooling' started by lmei007, Nov 25, 2007.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    Just did the chimney reline for my pellet stove. There are two pipes, one for exhaust and one for fresh air. The one close to you with a separated cap is for fresh air, a 3" alimiumn pipe. The one for exhaust is 3" stainless steel pipe specially for pellet stove. I need your professional advice to see is there anything was done wrongly. http://www.flickr.com/photos/lmei007
    thanks
Similar Threads: reline need
HVAC Heating & Cooling still need reline in my chimney? Nov 18, 2007
HVAC Heating & Cooling I absolutely need to use a common wire to install my Nest...which is the common? Dec 7, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Looking to buy 2 stage 17 seer AC Need Help Jul 5, 2016
HVAC Heating & Cooling Advice needed on HVAC air handler options Jun 6, 2016
