Just a quick question?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by justawop, Jan 20, 2009.
  1. justawop
    justawop New Member
    Jan 12, 2009
    I had my hot water pipes freeze(plastic pipes), thawed them and installed heat wrap. Checked for leaks and none found. Since they thawed when I turn the water off on all faucets, hot and cold, it kind of dribbles to a stop. before the freeze it shut off "instantly". Does this mean there is air in the pipes? What can I do to correct the problem? Thanks in advance
  2. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    Don't think it would be an air problem . Maybe freezing loosened some junk in the pipes & now its in the faucet .
  4. justawop
    justawop New Member
    Jan 12, 2009
    Thats what I thought first, but then realized that its on all faucets and the freeze happened after the hot water heater and it the dribble happens on both hot and cold water?
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Check the aerators for debris.
Similar Threads: quick question
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Quick vent question (near main stack) Mar 26, 2016
Plumbing Forum, Professional & DIY Advice Quick toilet drain slope question Aug 24, 2015
Plumbing Forum, Professional & DIY Advice Quick Question About Delta RP17454 Pull Down Diverter Nov 20, 2014
Plumbing Forum, Professional & DIY Advice Quick question about water softener. Brine tank is soapy. Is that normal? (with picture) Oct 18, 2014
