Just a few water softener questions...
Discussion in 'Water Softener Forum, Questions and Answers' started by jkats, Mar 8, 2013.
  1. lifespeed
    lifespeed Member
    Apr 27, 2007
    California
  2. ditttohead
    Jan 9, 2012
    Ontario California
    Reminds me of an episode of "My Name is Earl". Randy claims he would be great on the debate team because he can disagree with anything anyone else says.
    And yes, Nelsen does say the same thing, please do your research. Nelsen doesnt bother with residential flow recommendations, they assume most professionals understand the practical limits of equipment sizing and application. Their entire commercial line has recommended minimum and maximum flows. You ask for proof from Watts or Nelsen, I show you proof, the proof is wrong, sigh.
    A 4 cu. ft. system should work fine but will be outside of the engineering specifications for many residential applications. A properly sized twin alternating system would be a better fit. Not sure why this has turned into a multi-page discussion again.
  3. Gary Slusser
    Retired
    I don't see any confusion or ball busting on my part, just ditto and lifespeed's, because I have never had a customer suffer from too low flow or channeling problems.
    And I see you saying that you haven't either but, now ditto says downflow doesn't have channeling and that channeling isn't the problem blah blah blah... So why does he insist that low flow is a problem, in you opinion of course?
  4. Gary Slusser
    Retired
    Damn, you finally got it right! Nelsen does not have minimum flow rates for residential but do for their commercial softeners.
    And a 4.0 cuft in residential works fine.
  5. ditttohead
    Jan 9, 2012
    Ontario California
    Lol, you still dont grasp the concept. Maybe I can help.
    1" main line, 10 people in the house, 90 grains hardness, customer wants to maintain decent efficiency and regenerate approximatley every 6-7 days at 6 pounds of salt per cu. ft.
    10 people x 60 GPD x 90 gpg x 6 days between regeenrations =324,000 grains system needed for this application. So you would have no problem installing a 15+ cu. ft. single tank system? According to the logic of Gary, a 30" diameter tank will have no problem with residential flows. The recommended folw rates are just that, recommended. They are design parameters that need to be considered. They are "recommendations", not mandates. Why is it a bad idea to recommend a more appropriate design for an application? A 4 cu. ft. system should work ok. Is it ideal? Is it the best choice? No, but it may be slighly cheaper than a proper twin alternating system.
    Stop looking and digging for conflict where it does not exist.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I don't see where he did say low flow was a problem if its intermittent.
  7. Gary Slusser
    Retired
    Yep, all you've got left is the ability to make up an outrageous and untrue claim about me.
    I agree with your bottom line. In this case a 4.0 would work just fine.
Similar Threads: water softener
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Water Softener & Whole House Filtration Feb 8, 2017
Water Softener Forum, Questions and Answers Is my watersoftener broken? Jan 29, 2017
