junction box and code
Discussion in 'Electrical Forum discussion & Blog' started by lnfd27, Jul 20, 2008.
  1. lnfd27
    lnfd27 New Member
    Jul 20, 2008
    We are having a microwave installed above our stove. The contractor is dropping wire down to the basement to a junction box. He is then running a wire from the panel box to the junction box. Will this meet code? I thought the wire had to run from the appliance directly to the panel box. Thanks
    Lynn
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    A dedicated circuit is still a dedicated circuit even when it passes through and is exclusively spliced in a junction box. I am not a professional electrician, but what you have described sounds fine to me.
  4. CharlieM
    CharlieM New Member
    Jul 1, 2006
    Iowa
    I don't know why your contractor would not homerun the cable unless there are pathway issues along the way which can happen in remodels.
    I'm not a pro, but as far as I know from my reading of NEC, junction box is permissable as long as it remains accessible (ie, not buried behind drywall, etc).
  5. Wrex
    Wrex Member
    Mar 19, 2008
    New Jersey
    This is what I have read as well.
    It may also be the contractor cut the romex too short and it won't reach the box and this is a lazy effort to salvage the cable.
    Or he has a useless cut length of cable that hes trying to get rid of.
  6. leejosepho
    Nov 23, 2006
    That kind of sounds like a professional posing as a frugal handyman or DIYer, eh?!
  7. hj
    wire
    There could be any number of legitimate reasons to do it that way, and there is nothing improper about doing it that way. The only downside is if someone decides to make a connection to that J box someday and extend it to an outlet or light fixture.
  8. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Junction boxes are quite common. I use them to make running (fishing) wires easier. Especially when using conduit.
    If an electrician is working by himself, then it can be quite difficult to fish a wire a long distance. Easier if there is a helper to "push" while the other is "pulling".
    Anyway you can get in the situation where you are working by yourself, go down to basement and pull on wire, then the wire upstairs gets a knot in it, then run upstairs and free it, then pull some more wire, then another knot, back upstairs, etc.
    Well let's avoid that headache! Just install a junction box! (Saves time.)
  9. Wrex
    Wrex Member
    Mar 19, 2008
    New Jersey
    I understand that more then you know. But running up and down stairs 20 times because it keeps kinking is half the fun :rolleyes:.
    When I was fishing my new RG6 and Cat 5 phone lines I really thought the wire was testing me everytime I began pulling it was 10 feet kink 10 feet kink :D.
  10. hj
    wire
    I would have run the wire from the panel to below the stove and then pulled the wire up. That would have minimized the number of trips up and down the stairs.
  11. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Me too, but alot of people just drop wires into the basement and worry about them later... no big deal. I dont work like that, but whatever.
Similar Threads: junction code
Electrical Forum discussion & Blog Electric baseboard installation: no junction box behind it? Nov 25, 2016
Electrical Forum discussion & Blog Old Meter Box Junction Nov 9, 2016
Electrical Forum discussion & Blog Romex to THHN conversion in house junction box Oct 2, 2016
Electrical Forum discussion & Blog Hot tub wiring (outdoor junction box) Sep 1, 2016
Electrical Forum discussion & Blog Large junction box Jan 6, 2016
