Joining ABS to PVC
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BuickGN, Jan 25, 2005.
  1. BuickGN
    BuickGN New Member
    Jan 24, 2005
    Is this against code? My house is plumbed with ABS but I have access to a lot of PVC fittings/pipe and want to know if I can join them together. Which glue should I use if it is OK?
  2. hj
    pipe
    In most areas you cannot join them directly, but must use a transition coupling such as a Mission, No-Hub type, coupling specific for the two materials. Once you have made the transition, you cannot change back again, however.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    PVC to ABS
    The problem is, the so-called "glue" used for these materials iis not really glue. The work by chemical reaction that literally welds the pieces together. Since ABS and PVC have different compositions, the "glue" for one does not work on the other. That's why you would have to use a no-hub type connector.
  5. BuickGN
    BuickGN New Member
    Jan 24, 2005
    OK, makes sense to me.
  6. BuickGN
    BuickGN New Member
    Jan 24, 2005
  7. hj
    pvc
    Most codes do not allow a transition glue, but our gas utility, which has high pressure mains, used it all the time to transition from the old ABS lines to their new PVC ones. But they do not have to answer to any code authority.
  8. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    No.
    The chemistry doesn't change--you cannot "glue" PVC to ABS.
    Deb
    The Pipewench
  9. BuickGN
    BuickGN New Member
    Jan 24, 2005
    Well, I think I am going to just rip out the ABS where it goes into the CI drain and use a ty-seal with the PVC. I hear those are a bear to put in though. On the other end where I plan on keeping the ABS I will use some no-hub connectors.
  10. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    Buick - you could join the pvc and abs using no glue at all - try a rubber coupling if you have your heart set on a quick connection... personally I like to stick with abs
  11. Gary Swart
    Sep 1, 2004
    Yakima WA
    Abs/pvc
    I know you have extra fittings laying around, but ABS and PVC fittings are not all that expensive. Why not just bite the bullet and get the fittings that match you system? I had a bunch of left over ABS fittings from a job I did, and I just put them on a table in my driveway like a mini yard sale. Sold some, tossed the rest.
Similar Threads: Joining
Plumbing Forum, Professional & DIY Advice joining replacing cast iron with plastic Nov 8, 2013
Plumbing Forum, Professional & DIY Advice joining ABS pipes partially under water Jul 12, 2013
Plumbing Forum, Professional & DIY Advice joining pvc to old cast pipe.... Mar 12, 2012
Plumbing Forum, Professional & DIY Advice Joining Dissimilar Metal Pipes - Out of New Well and Expansion Tank Feb 27, 2012
Plumbing Forum, Professional & DIY Advice Joining unthreaded brass pipe Jun 29, 2010
