Jet Tub wireing
Discussion in 'Electrical Forum discussion & Blog' started by Diamondintheruff, Apr 23, 2008.
  1. Diamondintheruff
    Diamondintheruff New Member
    May 16, 2007
    redoing my bathroom and came across the pump for my jet tub .... my question is the ground on the outside of the unit is not attached to any thing did a little reasearch and found this page...
    about half way down it says that that should be attached to "proper equiment grounding condutor" can some one help me out so i understand what that means? i do know the inside ground is hook up as i opened the cover to check.:confused:
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Well whatever instructions those are they are wrong.
    The external lug is NOT for grounding, it is for bonding.
    The bond required in NEC 680.74 is attached there.
    This is from the 2005 NEC:
    680.74 Bonding
    All metal piping systems and all grounded metal parts in contact with the circulating water shall be bonded together using a copper bonding jumper, insulated, covered, or bare, not smaller than 8 AWG solid.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    North Carolina
    The lug on the motor is for bonding to such items as water pipes or other metal used in the installation of the tub.
    The equipment grounding conductor is supplied with the branch circuit and does not need to land on this lug
Similar Threads: wireing
Electrical Forum discussion & Blog Conduit Runs and box wireing Feb 19, 2011
Electrical Forum discussion & Blog Well Pump Wireing Mar 26, 2009
