jet pump problems
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by taf121, Mar 23, 2006.
  1. taf121
    taf121 New Member
    Mar 23, 2006
    I'm trying to get a jet pump working again after not using it for a few years.
    (I was told that it is a jet pump system...two pipes going out)
    I primed the pump and have water pressure of app. 38 psi. at the pump housing. The pump keeps running but the pressure will not build any higher than 38 psi. I have no water going to the pressure tank. The tank has 20 psi. of air pressure. What could be keeping the water from going into the pressure tank?
    The tank is a Well Trol WX 102. The only thing between the pump housing and the tank is some sort of valve that is spring loaded. I tried adjusting the valve with no change. Is this what is called a check valve and could it be keeping the water from the pressure tank? Thank you for any help.
    Tom...
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The valve could be a back pressure control. It is used to make the pump work properly. With only 38 psi and no water going into the tank, I would think the valve is shut off completely.
    Is this the original pump, or one you just installed?
    bob...
  4. taf121
    taf121 New Member
    Mar 23, 2006
    This is the original pump. How would I check the valve?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    It should have a bolt or screw that can be turned out and in. In increases backpressure and out decreases pressure to the jet in the well.
    bob...
  6. taf121
    taf121 New Member
    Mar 23, 2006
    I just took the valve apart and didnt see anything wrong.
    I then put it back together and backed the bolt all the way out.
    The pressure only increased to 40 psi. What would happen if I eliminated the valve completely?
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    They are necessary on deep set jets. It all depends on your water level. I would leave it in line and while running a lot of water adjust it so the pump stays quiet while running.
    bob...
  8. taf121
    taf121 New Member
    Mar 23, 2006
    I adjusted the screw to the original position that I found it.
    The pump still runs continuosly...at 40 psi. (will not increase above 40 psi.)
    I still am unable to get water into the pressure tank and of course no water to the outlet hose connection.
    Would a defective pressure tank keep the water from entering the tank?
    Do you have any other suggestions on getting water to the pressure tank? Thank you..
  9. speedbump
    Jul 15, 2005
    Riverview, Fl.
    If you have your tank aired up to less than 40 psi, some water will enter the tank. Don't expect it to take in a lot of water because that is not how bladder tanks work. The pump will shut off when you get the pressure switch set to 19/39. I don't know why your not getting any water out of a faucet. Check all the valves and any filtration.
    bob...
Similar Threads: pump problems
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Air Lift Well Pump Problems Nov 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Problems pumping lake water to cottage Aug 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump problems Oct 17, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Shallow or bored well pump problems Jun 3, 2015
