Jet pump pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Sam Downing, Nov 13, 2012.
  1. Sam Downing
    Sam Downing New Member
    Nov 13, 2012
    Maine
    I just replaced my 1/2hp jet pump with a1/2hp new pump, and the expansion/pressure tank (25gal) with similar size. I am drawing water, but only enough to run a single faucet and not enough to reach the second floor or power the first floor shower. The switch is set 20-40 as factory settings and the pressure tank is 25lbs. To increase my pressure is it simply increasing the switch settings to 40/60? That's where the trigger points were on the previous pump. My gauge is currently reading 25lbs.
    Thanks for your help
    Sam
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Yes all you need to do is increase the pressure switch setting. That is as long as your new pump can build that much pressure. You don't want to get close to the "max" pressure that pump can build.( check the pump specs) Depending on which 1/2 HP you have, the max pressure might only be 60 PSI. Which means you don't want to set the pump to shut off any higher than about 55 PSI.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    You will also have to increase the air precharge on the tank.
  5. Sam Downing
    Nov 13, 2012
    Maine
    I called the vet for a house call in the morning.
    I'll enjoy a cold beer with my feet up til then.
Similar Threads: pump pressure
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Pressure Switch constantly cycling on and off Mar 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure pump problem Dec 21, 2016
