Jet Pump or Sprinkler Pump?
Discussion in 'Irrigation / Sprinkler Forum' started by amartin725, Jun 27, 2005.
  1. amartin725
    amartin725 New Member
    Jun 27, 2005
    I’m drawing off a holding tank to water my lawn through a ‘professionally’ installed underground sprinkler system (The tank is fed from a separate low-volume well) The draw from the tank to water the lawn will range from 3 – 8 GPM depending on the zones, with a target pressure of 40-50 psi (I have 11 zones, none with more than 4 heads per zone on a piece of land just under ½ acre). The pump will sit either on top of or next to the tank and can draw from either from a spout on the bottom of the tank or from a pick-up tube inserted down from the top, the configuration has not been set yet. Most sprinkler pumps are designed for heavy volume, much more than what I need, but a jet pump seems overkill for this. I will set up whatever is needed for the long term benefit, but want to make sure I spend my money in the right place.
    Thanks,
    Al
  2. hj
    pump
    Sprinkler pumps have a limited "lift" component so if you use one you will want to connect it to the water tank at the bottom so the water will flow to the pump. If you mount the pump above the tank, you might be better off with the jet pump, which can draw water better.
Similar Threads: Pump Sprinkler
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
Irrigation / Sprinkler Forum Sprinkler Pump lost/losing prime? (Florida) Mar 23, 2013
Irrigation / Sprinkler Forum pump start relay bad? (hunter sprinklers) Oct 4, 2011
Irrigation / Sprinkler Forum Lawn Sprinkler Pump Short Cycle Jul 20, 2010
Irrigation / Sprinkler Forum Replacing a Goulds J10S 1 hp pump for home sprinkler system Jul 6, 2010
