jb weld?Toilet tank crack
Discussion in 'Toilet Forum discussions' started by cwhyu2, Mar 3, 2009.
  1. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    10 min ago went past the bathroom and heard water running onto the floor.
    Found leak from cracked tank that been patched before. Water to W/C is
    off now.This is rental property and the owner will take days to return my
    call.Has anyone succesfully temporaly patched a crack in a toilet tank?
    JB weld comes to mind.I have never even tried.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    JB Weld is nothing more than epoxy. It may provide a temporary repair (or not) but a broken tank is final. You will need a new toilet. Your landlord is required to provide a functioning toilet. I would imagine this is an old full flow, so he is stuck with a new low flow.:)
  4. Terry
    Aug 17, 2004
    Gary is right. it's time to shop for a new one.
    If you try to fix a cracked tank, and it gives out while you are at work, the bill could be in the tens of thousands.
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I will only turn it on when needed and off at all other times.Like I said the owner is Iwon`t use the words. thanks guys!
  6. Cass
    Cass Plumber
    Nov 12, 2005
    I have used JB a few times and when I am spanning a crack what I do is to coat a piece of paper on both sides with the JB...be sure the paper extends at least 1" beyond the crack every where...then apply it and smooth it with a disposable putty knife...
  7. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Just going to dump a bucket water in the bowl for now.thanks again for the
    info
  8. Sandpiper Plumbing
    Sandpiper Plumbing Plumber
    May 4, 2008
    Northern by birth, Southern by choice
    I've had customers break pieces off tanks before and I've adhered them back on with a 30-minute two-part epoxy.
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Thanks W/C is being replaced saturday afternoon.
  10. wooo stash
    wooo stash New Member
    Mar 7, 2009
    Sealing a tank with silicone
    About ten years ago I noticed my toilet tank leaking~a crack in the back of it, don't ask how it got there that's a mystery. I emptied the tank and dried it up and put a bead of silicone on the inside~waited 24 hours and put a second bead over it. the next day I filled the tank and it hasn't leaked a drop all these years. Just a little tip for anyone with a mystery crack....
  11. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Nothing in my career of plumbing involves JB weld.
  12. Terry
    Aug 17, 2004
    Great idea, tube of Silicone $5.99
    Cost to repair the home if it gives out while you are at work, up to $100,000.00 in damages.
    Los Vegas baby. I guess you like to gamble.
    [​IMG]
    This tank is 34 years old. Would you want to Silicone this one too?
    Notice the nice mold on the bottom of the tank.
  13. Gary Swart
    Sep 1, 2004
    Yakima WA
    Heck yeah! Don't need no stinking new turlet, this one's been fine for 40 years! Why shoot, my daddy used it, and what's good enuf fer dad is good enuf fer me. Why shoot, Billy Mays swears by this stuff to fix anything. Cain't afford a new turlet no how, gotta make the payments on my RV. Pass me that there sillycone.:p
  14. achutch
    achutch Member
    Oct 20, 2005
    Vermont
    My next door neighbor found a crack inside the tank of her second floor toilet that ran the entire length where the floor of the tank meets the back wall, and partially up the right side.
    She made the right decision and replaced the toilet.
    We advised everyone in our annual condo association meeting to inspect the insides of their tanks, especially those people who had the original toilets installed in 1986.
    If that tank had broken, there would have been major damage in my neighbor's unit, as well as in mine as that toilet is on the other side of the wall where my computer room is.
    I have seen what a major leak can do. In 1985, I was living in a new 3 unit apartment building. The washers were on the second floor. I had one end unit. My washer was brand new and professionally installed. The tenant in the opposite end unit installed a used washer with used hoses. She left with the water turned on, a hose burst, and the entire building got flooded; my first floor having at least an inch of water in it. Then, when I arrived home to find all my furniture out on the lawn, the tenant whose machine had caused the flood was out on the lawn sipping on a glass of wine and tee-heeing that it was "just one of those things"!!!
    I would rather spend money on a new toilet and correct installation of water using equipment than risk a flood!
    achutch, nice and dry in Vermont
  15. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Toilet was replaced,but all the info is great stuff.Nobody wants to come
    home to a waterfall.
  16. Cass
    Cass Plumber
    Nov 12, 2005
    Of all the epoxys I have use for various things JB Weld is about as good as it gets...when applied correctly it works well...
  17. Gary Swart
    Sep 1, 2004
    Yakima WA
    Epoxy is great for some things. But the point of this thread is using it to permanently patch a cracked toilet tank. In my opinion, this would not be a satisfactory permanent fix. Temporary to buy a week or so until a new toilet could be obtained, maybe. I would still opt for the silicone because it would expand/contract with the tank, epoxy would not. Nothing against JB Weld or Mighty Putty for some applications.
  18. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    In my first post it was to be temporary fix,Moot point for me as I replaced it
    this past weekend,but it is a good topic.It could keep someone from making
    a disasterous decisision.
  19. wooo stash
    Mar 7, 2009
    That's a scary looking picture~much bigger crack than I had. Actually I only originaly used siicone as a temporary fix. It work so well that I actually forgot about it for years . This wouldn't work in every situation of course and its probaly best to start shopping for a new toilet. I'm finally replacing mine because I'm doing some remodeling in the bathroom.
  20. Gary Swart
    Sep 1, 2004
    Yakima WA
    That's too often the case with temporary fixes, and we're probably all guilty of it. We just put it of for awhile, then it's forgotten about.:)
Similar Threads: weldToilet tank
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Monday at 5:17 AM
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
