Jado three handle tub/shower setup options
Discussion in 'Shower & Bathtub Forum & Blog' started by britr07, Jan 31, 2011.
  1. britr07
    britr07 New Member
    Jan 31, 2011
    Baltimore, MD
    new to site. using jado 818 series. tiled wall finished for three handle tub/shower setup. contractor "plumber" used jado 4/3 diverter as center and hot and cold handles. works, but not ideal.
    anyone know of three handle valve body to use with jado 818 handles? any way to modify pricepfister three handle tub/shower valve body to make compatible with jado 818 handles.
    thanks, Troy
  2. jadnashua
    Swapping handles from different brands is sort of like trying to put a Chevy engine in a Ford...while maybe possible, not likely without a lot of machining or other work. Also, if those handles are into straight valves, and this is a remodel, it would not pass code. All new/remodeled (not repaired) showers require anti-scald technology, and straight volume controls do NOT have this capability. An inspector would likely fail it, and if you aren't getting an inspection, you are at risk for other problems (financial and otherwise) when it comes time to sell, too.
    this should have been addressed before you tiled.
Similar Threads: Jado three
Shower & Bathtub Forum & Blog Old tub three handle faucet leaks Apr 24, 2016
Shower & Bathtub Forum & Blog Three Handle Diverter - Changing Shower/Tub Diverter Turn Direction Dec 26, 2015
Shower & Bathtub Forum & Blog Which of these three cast-iron alternative bathtubs is the most durable? May 4, 2015
Shower & Bathtub Forum & Blog Leaking bathtub faucet. Need help identifying three handle variety. Dec 18, 2014
Shower & Bathtub Forum & Blog Replacing a three handle tub shower faucet with Moen Posi-Temp Feb 22, 2014
