Jacuzzi Question
Discussion in 'Shower & Bathtub Forum & Blog' started by Verdeboy, Mar 1, 2008.
  1. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I'm doing a bunch of odd jobs for a customer, and they also want me to check their Jacuzzi.
    They said it was working fine until they had to replace the heating element. Now, the pump makes a humming sound, but the jets don't work, and it won't heat up either. They had a "friend" replace the heating element, so it may not even be installed correctly. But why would that prevent the jets from working?
  2. bigbird
    bigbird New Member
    Jan 31, 2008
    Winnipeg, Manitoba
    Sounds like he didn't wire it back up properly. If the pump hums and doesn't turn I would suggest one of two things:
    1) He didn't wire it back up for 240V and it's only getting 120V. Test it with a meter for correct voltage.
    2) Unlikely, but the bearings in the pump may have seized. Rotate the pump by hand to see if this is the case.
    I'll go with door #1.
  4. jadnashua
    Also, keep in mind that you'll ruin the pump fairly quickly if it is run without enough water in the lines.
  5. Verdeboy
    Jun 12, 2006
    Score another one for the handyman!!
    Once I got there and assessed the problem, it was obvious that the pump just needed to be primed. They forgot to purge the air after replacing the heating element, and the jacuzzi wasn't used for months. Quick fix, and another happy customer.
Similar Threads: Jacuzzi Question
Shower & Bathtub Forum & Blog Question on installing a Signa Jacuzzi Soaker Tub Jan 17, 2011
Shower & Bathtub Forum & Blog Insulating a jacuzzi tub Mar 14, 2015
Shower & Bathtub Forum & Blog jacuzzi tub Nov 11, 2014
Shower & Bathtub Forum & Blog Adding a step to an outdoor pool jacuzzi Jul 26, 2014
Shower & Bathtub Forum & Blog Water Jet jacuzzi timer Feb 5, 2014
