Jaccuzzi Perfecta EZ33959 Toilet
Discussion in 'Toilet Forum discussions' started by LMSteimel, May 28, 2011.
  1. LMSteimel
    LMSteimel New Member
    May 25, 2011
    I bought this toilet at Lowes and when I installed it I found that water leaks from the tank. If I shut off the water supply it leaks completely. Water does not go onto the floor so I know it is getting past the flapper assembly. I used joint compound on the big nut underneath and on the big rubber gasket and tightened the nut with some large channel locks. It still leaks and the only thing I can think of is to take the tank back off and put gasket sealer under the flapper assembly on the inside of the tank.
    Does anybody have any ideas on a solution?
  2. Terry
    Aug 17, 2004
    Are you sure it's not not flapper?
    I've never used joint compond on a toilet before.
    These are our instructions
    They should work for any brand.
Similar Threads: Jaccuzzi Perfecta
Toilet Forum discussions Jacuzzi Perfecta Toilet Problems Oct 8, 2012
Toilet Forum discussions Jacuzzi Perfecta May 10, 2011
Toilet Forum discussions Jacuzzi Perfecta Dec 13, 2009
Toilet Forum discussions Toto Dalton vs Jacuzzi Perfecta Sep 11, 2009
