Jaccuzzi parts ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jeff_bathroom, Jun 12, 2008.
  1. jeff_bathroom
    jeff_bathroom Member
    Dec 15, 2005
    Florida
    Hi,
    I just took a look at my parents bathroom. The insect guy reported to
    them that there was a big leak under the house. Sure enough, they'll have to get the sub-floor replaced and maybe the jaccuzzi itself (which I'll probably end up doing).
    Thing is that the tub still looks fine for the most part. I remember them trying to get replacement valves that control the bubble flow since they no longer turn. That could be the source of the leak. No luck anywhere finding parts.
    Does anyone know of a place that sells replacement parts for old jaccuzzi tubs, like about 25 years old?
    -- Jeff
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Are you using "Jacuzzi" as a brand name or as a generic term for a spa? If it is the brand name, I'd start be getting any/all identification numbers and names possible, especially a model number or name. Try to identify every part that you will need. Some may be standard plumbing parts, other may be brand specific. Then contact Jacuzzi and see if they have the parts you need. I would not hold out much hope in finding obsolete parts at a dealer, but you never know. It could be that newer controls might retrofit. I had that experience with my 10 year old Hot Springs Spa recently. My heat failed and the replacement was totally different in appearance but it had been designed by Hot Springs to retrofit older spas. Works great!
  4. Garydaplummer
    Garydaplummer Union plumber/pipefitter-self employed
    Jan 5, 2008
    Mechanicsburg, PA
    Try on line auction
    Customer of mine had old Jacuzzi brand tub and tried all over to get parts. Found one supplier that could get them but the shipping and price was outrageous. Someone suggested trying an on line auction and he found a company in New York I think that sold him new Jacuzzi outdated stock for 25% of what the supplier wanted with a money back guarantee. It's worth a try. Sorry, the name of the on line auction (You know who it is) gets blocked here for some reason?!
  5. jeff_bathroom
    Dec 15, 2005
    Florida
    Wet subfloor - replace it?
    Thanks for the suggestions and info guys.
    It's an original Jaccuzzi, but my folks tell me that a plumber
    came awhile back and replaced one of the faucets and said that
    they were Delta. Not sure if Jaccuzzi used Delta or if those were
    retrofit later.
    They've had no luck getting parts. I was thinking that we could try to
    get something similar from another manufacturer.
    Problem now is whether to yank the tub and replace the subfloor.
    There's about an eight foot square area that is soaked.
    If it's directly beneath the tub and not so much under the tile floor, I'm wondering if we can just fix the leak and dry out the plywood with fans from underneath. Seems that even if the plywood delaminates some, the tub will still be sitting on the plywood supported by the joists. I'm really trying to
    avoid taking out the tub. That will mean removing tile above the tub lip
    and all that. We may not be able to get matching tile. It will be pretty expensive and/or time consuming even if I do the work. Are there any real pitfalls to leaving the subfloor as is?...e.g. is there a big risk of mold, etc? or is this just a structural question?
  6. hj
    jacuzzi
    The faucets are Delta, but the air controls probably are not.
  7. jeff_bathroom
    Dec 15, 2005
    Florida
    Thanks HJ,
    The air controls are stuck...can't turn them.
    Any third-party replacements, or do you think I can still
    get them from Jaccuzzi ?
  8. jeff_bathroom
    Dec 15, 2005
    Florida
    Wet subfloor - anyone used epoxy fillers instead of replacing?
    Hi,
    I noted some products that you can pour onto a water damaged subfloor to stiffen it back up instead of replacing the subfloor. Anyone have luck with that method?
Similar Threads: Jaccuzzi parts
Plumbing Forum, Professional & DIY Advice Grundfos Timer Driven Hot Water Recirculation Pump - Name the Parts? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Prestige 110 Parts? Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Broadway Faucet Parts Sep 23, 2016
Plumbing Forum, Professional & DIY Advice Globe Valve Parts Jun 19, 2016
Plumbing Forum, Professional & DIY Advice Parts for Seametrics MJ Pulse Meter Aug 26, 2015
