J-Class Well Water Pump S1CY-S Not Pumping Water
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dfannin, Apr 14, 2013.
  1. dfannin
    dfannin New Member
    Apr 14, 2013
    Vero Beach FL
    Hi All,
    Recently we noticed our water pump had a minor leak. Before we could fix the leak the pump stopped pumping all together. We have since sealed all the leaks but this did not resolve the problem. What is happening is the pump will turn on for about 30 seconds and then it shuts off. We noticed the pump itself was very hot. Do you know anything about the insides of the pump and what could be going on?
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Not sure what kind of leak you had, pump seal or what ?
    If water got into the Start Switch it could be stuck in start or not making contact.
    Does it pump water ?
    You could have a bad run capacitor also.
    It you replaced the pump seal, then the Impeller could be out of center alignment and rubbing on the pump housing.
    Good Luck
Similar Threads: J-Class Water
Pumps and Tanks Well Forum & Blog. Water is life. Franklin J-Class Pumps Apr 19, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Can/Should I install water meter in Single Family well fed system? Tuesday at 7:43 AM
Pumps and Tanks Well Forum & Blog. Water is life. Newb questions about water storage Tuesday at 6:26 AM
Pumps and Tanks Well Forum & Blog. Water is life. 4 Inch Well, Water Full of Sand, Ideas Welcome! Monday at 11:58 AM
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Sunday at 7:40 AM
