ISE Hot Water Dispenser Installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mortimer74, Dec 13, 2007.
  1. mortimer74
    mortimer74 New Member
    Dec 13, 2007
    ISE hot water dispenser tank failed after 3 years and replacing with the new stainless model that is larger. Due to a tight space, i cannot get the new tank as close to the faucet, and the tubing needs to be replaced with longer tube. There are three tubes, and i have questions about 2 of them.
    ISE authorized service and ISE customer service say that the blue 1/4" tubing cannot be replaced and that i need to buy a new faucet ($180)! Does anyone have another source for this tubing? It seems similar to 1/4" poly for cold water dispensers.
    The latex tubing has thicker walls than what is stocked in similar material at Home Depot. Any problems there?
  2. jadnashua
    The stuff may be heat sealed, or crimped on at the factory, and there's no convenient way to do a field repair. This is just a guess.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    If you can find a fitting that matches the tube size you should be able to splice in a piece of tubing that is rated for the temperature and pressure. If it is a cold water line you could use nylon or perhaps high pressure rated polyethylene. If it is a hot water line then you need to be careful to get properly rated fittings and tube.
  5. hj
    tubes
    The ISE unit is an atmospheric unit so the hot water has NO pressure on it. You can use John Guess slip on fittings, which is what ISE uses at the tank.
Similar Threads: Water Dispenser
Plumbing Forum, Professional & DIY Advice Air Gap pumping water outside, Dishwasher, Air Gap and Garbage Dispenser all are new Oct 4, 2015
Plumbing Forum, Professional & DIY Advice Insinkerator hot water dispenser tank with non insinkerator faucet? May 30, 2015
Plumbing Forum, Professional & DIY Advice Hot water dispenser help Jan 20, 2013
Plumbing Forum, Professional & DIY Advice Instant hot water dispenser Oct 10, 2011
Plumbing Forum, Professional & DIY Advice Instant Hot Water Dispenser Problem Feb 6, 2011
