Is this trap OK?
CountryBumkin
Active Member
Orlando, FL
If I understand your last post, and using the picture above, the vertical section that has no venting (where the AAV is in the photo) is actually in your wall and where the AAV is shown in the photo is a real vent line going to roof. If this is the case, the AAV is not needed under the sink.
Am I confused on what is in the wall?
EDIT: Okay, I think I'm starting to follow you. You are looking for a way to vent the "current p-trap setup" so you don't need to cut a notch in the cabinet floor and not lower the p-trap to below the waste pipe at the wall.
SAS
Yes, your last comment is correct. Sorry I wasn't clear about that picture. It is just a sample that I found on the Internet of a vertical line with a tee and an AAV. In my case the two "best" choices are to modify the cabinet so that I can lower the trap or to open the wall and raise the height of the stub out from the drain pipe in the wall. I'm looking for something that is up to code and doesn't require either of those efforts.
(and thanks for all of your help)
SAS's plan would look somewhat similar to this except SAS would get the P-trap part right and not have a horizontal part int the vent line going up to the AAV. If he had to jog, he would use 2 45s .
index.php
Terry's suggestion is more like this:
but probably with a little bigger hole to be able to move things a bit.
Asktom
Victor, MT
The AAV would protect the trap from siphoning due to negative pressure. The vent in the wall would protect the trap from positive pressure.
There are ways of venting an island sink without using an AAV.
Bottom line: before the outlet of the p-trap can turn down, that arm coming out of the trap must be vented. IF allowed where you live, an AAV will satisfy that requirement, but it's best to avoid using one as it's another maintenance item to deal with.
