Is this shower plumbing too involved to do?
Discussion in 'Shower & Bathtub Forum & Blog' started by reybo, Aug 26, 2009.
  1. reybo
    reybo New Member
    Aug 26, 2009
    Virginia
    This 1952 house with still nice tile showers and real plaster walls could do with a modern mixer valve in the shower in place of the old hot/cold valves it has now.
    [​IMG]
    I can get a couple of smitty plates to cover the old holes in the tile. The problem is the plumbing behind the tile. Threaded steel pipes and some bronze fittings. Can I change that to a mixer valve without tearing up the plaster and the tile?
    [​IMG]
    The new plastic lines and valves went in last year, and we left the wall open for the project we're facing now.
    Appreciate your comments.
    reybo in Virginia
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The valve is attached with union nuts, so you can get it out without too much trouble. A new valve can be installed coming off the ball valves you have with male threaded adapters to whatever tubing type you wish to use...copper, pex.
  4. reybo
    reybo New Member
    Aug 26, 2009
    Virginia
    Separating the vertical pipe to the shower head from the horizontal
    The subject combined with the pic tells my problem. The only thing easily detached is the new valves & lines. How do I get the T unscrewed from the vertical steel pipe to the shower head without tearing out the wall? That T is 1/2" from the plaster. There's no turning it.
    Copper or plastic pipes and there''d be no problem.
Similar Threads: shower plumbing
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Shower remodel plumbing dilemma Dec 8, 2015
Shower & Bathtub Forum & Blog Finish Work Shower Plumbing Fixtures Aug 15, 2015
Shower & Bathtub Forum & Blog Custom Shower Plumbing Rough-In Advice Needed Jul 8, 2015
Shower & Bathtub Forum & Blog Help with Large Master Shower plumbing Mar 17, 2015
