Is this pump to large
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by 85ray, Jan 17, 2013.
  1. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    I just purchased some land with a well but no pump had the well flow tested at 22gpm the well is 343' deep static is 241' the well outfit gave me 3 pump options Gould's 2 HP 10 gpm, Gould's 3 HP 13 gpm, or Gould's 3 HP 18 gpm. All with 1 1/4 sced 120 pipe. So I want to get aslant gallons a min with out hurting the well and I read in one place that 1 1/4 pipe is only rated at 2 HP is this true and on the flow charts it shows the 18 gpm would over draw the well but at 0 psi will I ever get to 0 psi I plan on building a 4 bedroom 2 1/2 bath house with bath in shop and garden and watering some grass I am super confused astronomy to wich pump and what pipe to get
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Do you know the pumping level while they were getting 22 GPM? Because if it didn't pull down much below 241', the 2 HP, 18 GPM will work. But if it pulled down close to 340', you would need the 3 HP to get the 18 GPM, or the 2 HP, 10 GPM will get about 13 GPM. The 1 1/4" pipe is fine.
  4. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    The logged started at 241' and 13 gpm and in 15 minutes it stoked to 248' and 22 gpm and pretty much stayed at 248' for another 1 hr and 40 minutes
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Since the pumping level doesn't pull down more than 248', the 13GS20 will get you 15 GPM.
Similar Threads: pump large
Pumps and Tanks Well Forum & Blog. Water is life. Well started pumping large amounts of sand, now no water Sep 17, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Is a 30 gal ejection pump basin large enough for in-law suite? May 24, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Pumping large amounts of well water May 31, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Friday at 6:21 PM
Pumps and Tanks Well Forum & Blog. Water is life. Flat or twisted cable for deep well pump Thursday at 8:25 AM
