is this plaster or asbestos on my blueboard?
Discussion in 'Remodel Forum & Blog' started by aavguy, Sep 28, 2010.
  1. aavguy
    aavguy New Member
    Sep 22, 2010
    Pittsburgh, PA
    cutting into closet wall which is blue board and plaster.... please tell me this thin layer of gray stuff over the blue board is plaster and not asbestos? It's less than a quarter inch thick... Typical?
  2. Cookie
    Cookie .
    Oct 7, 2005
    I would think it probably isn't. In older homes with ceiling popcorn paint they would mix the two, but I would doubt the closet from what you are saying, but only a test would show for sure. Even then with the popcorn paint they would mix in a horse's hair and that, sometimes would scare people, too. Pittsburgh is noted for older homes and there's alot of places you can call and have it checked beforehand. A restoration service can be recommended through your homeowners. My homeowners paid for me to have it done.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Get it tested.
  5. aavguy
    aavguy New Member
    Sep 22, 2010
    Pittsburgh, PA
    is the plaster coat that goes over blue board typically gray? I always thought it was white so that's what made me question it I guess. it really doesn't appear like there are strands of fiber, looks like gray concrete almost.
  6. Cookie
    Cookie .
    Oct 7, 2005
    If they used the kind that isn't premixed, that powder is gray and maybe, they didn't add enough of water to bring the color lighter.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Get it tested to know for sure.
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    I finally found an asbestos test kit: $14 for the kit, plus $20 if you actually want the lab to tell you the test results.
    Apparently under 1% of asbestos and 99% air, by weight, is 'below the radar'.
    Before I disturb my old acoustic tile ceiling I will be looking into rental fans and filters to pull new air into the room while I'm working.
    Finding the proper equipment, ACHs, etc., is going to be at least an hour's worth of research, phone calls. :(
  9. jimbo
    jimbo Plumber
    San Diego, CA
    Asbestos rarely "looks" like what you are thining asbestos should be. The fibers are microscopic, which is why that get to your lungs so badly
  10. aavguy
    aavguy New Member
    Sep 22, 2010
    Pittsburgh, PA
    Well, here is a pic of the blueboard and gray stuff (plaster?)... I think I overreacted here. I simply though plaster was always white. IMG_1081.jpg
  11. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    From my test kit
    ". . .any building material that is not glass, wood, steel, yellow or pink fiberglass could contain asbestos. . ."
    from 1900 to 1978.
  12. dlarrivee
    Jun 28, 2009
    Canada
    They put Asbestos in nearly everything.
    Not all of it is "friable" though.
  13. jadnashua
    Before we got smart, they used asbestos fibers in lots of things as a benign filler. Now we know it is not so benign. Not that it will kill you on contact or anything like that, but if you break the fibers into small bits and inhale them, your body can't get rid of them, and this can cause all sorts of issues, most of which are the result of long-term exposure. So, the last thing you want to do is sand something containing asbestos, or do anything that generates dust that contains it.
  14. Redwood
    Dec 15, 2007
    Service Plumber
    Can you say Mesothelioma?
    Test It!
Similar Threads: plaster asbestos
Remodel Forum & Blog Plaster ceiling and wall crack repair product Aug 21, 2013
Remodel Forum & Blog Plaster tips Dec 8, 2012
Remodel Forum & Blog Removing Ceiling made of drywall, chicken wire, and plaster Nov 28, 2012
Remodel Forum & Blog Recipricating saw blades for plaster Jun 14, 2010
Remodel Forum & Blog Zinsser B-I-N and Venetian Plaster Apr 5, 2009
