Is this OK? rough in valve
Discussion in 'Shower & Bathtub Forum & Blog' started by FJK, Jan 16, 2008.
  1. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    I'm replacing an old, simple Moen tub/shower rough-in valve with a new Moen posi-temp valve. Due to space limitations of a vent pipe next to the rough-in valve, I need to come out of the cold side of the valve with a male/female 90° fitting (solder in). Is this OK? See image 15. Image 16 shows the new valve mocked up off the old valve's tub spout to indicate why I need to come out of the valve with a 90.
    Finally, image 12 shows the existing plumbing that has air hammer risers & the close proximity of the vent pipe I mentioned earlier. I plan on eliminating the risers when I install the new rough-in valve. Any comments or plumbing routing suggestions for image 12.
    Thanks, FJK
  2. jadnashua
    My unprofessional opinion, you'll be fine. Note, those air chambers typically become useless after a few months unless you shut off the water at the main, then open up the valves and drain the pipes. The air trapped there gradually gets absorbed. You shouldn't need them, but if you want a water hammer arrestor, put in a real one - they cost about $12 each at a big box store.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    hammer arrestors cannot be buried in a wall!
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Remove the internal parts of that valve before soldering. Should be nothing but metal in there when it's hot.
  6. Rancher
    Rancher Guest
    Seriously? Where else would you put them, my house passed inspection with them in the walls.
    Not trying to start an argument, just trying to learn for the next house.
    Rancher
  7. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    They can be placed in the wall but should be accessable for service/replacement... (access panel...)
  8. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    In some jurisdictions, a code approved arrestor can be buried if it's manufacturer's installation instructions say it can.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    That is what I would do!
Similar Threads: rough valve
Shower & Bathtub Forum & Blog Hansgrohe 35015 rough in valve help Nov 26, 2015
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Flow restrictor on Delta rough in valve??? Nov 8, 2014
Shower & Bathtub Forum & Blog Help to identify rough in valve/ need trim Sep 8, 2014
Shower & Bathtub Forum & Blog Tub/Shower rough valve quality/durability question Feb 8, 2014
