Is this drain arrangment code OK?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by novaee04, Apr 14, 2014.
  1. novaee04
    novaee04 New Member
    Apr 14, 2014
    Electrical Engineer
    Allentown, PA
    Looking for opinion on whether this is code OK or not. It is inch and a half coming down from a sink, and it goes through this to wye into a 2 inch horizontal drain. Ignore the pitch of the short section, I will make sure that is correct. drain.jpg
    Thanks
    Sean
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    How about a photo of the trap and vent installation?
  4. Bill Shack
    Bill Shack 30years plumbing 10years plumbing inspector
    Mar 10, 2014
    retired
    montreal quebec Canada
    Not to code, where is the trap, also you can not use 90 elbows on the flat or from vertical to horizontal.
  5. novaee04
    novaee04 New Member
    Apr 14, 2014
    Electrical Engineer
    Allentown, PA
    Here is the rest of the stack. After going through the floor, the 1 1/2" goes up to a san tee which will come out through the wall to the trap under a sink
    Blll,
    I do not follow your comment about the 90 elbows. When you say you cannot use them on the flat, or from vertical to horizontal, why not, and what should I do instead?
    Thanks
    Sean
  6. Terry
    Aug 17, 2004
    You have two medium bends in the wrong location.
    From the wye, continue to the other side of the stud, and work backwards to the lav. You're trying to be too cute there, and you've run out of space.
    Bends on the horizontal need to be 45's and long turns.
    Bends from vertical to horizontal need to be 45's and long turns too.
    The only bend that works there is the horizontal to vertical, which can be medium.
  7. novaee04
    novaee04 New Member
    Apr 14, 2014
    Electrical Engineer
    Allentown, PA
    Thank you all for the response. I will update and then repost to confirm what i did is OK
    Thanks
    Sean
  8. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    What? Who's code?
  9. hj
    quote; What? Who's code?
    EVERYONE's, if it is a good code, and not the "anything goes if it is cheaper or easier" code. Even IF this were acceptable, it would be a "bear" to snake those elbows, since it is only 1 1/2" pipe.
  10. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    The horizontal elbow should probably be a long sweep but over that short distance it wouldn't make much difference. It is pretty ugly piping though.
  11. novaee04
    novaee04 New Member
    Apr 14, 2014
    Electrical Engineer
    Allentown, PA
Similar Threads: drain arrangment
Plumbing Forum, Professional & DIY Advice Is this drain arrangment code OK? - Update Apr 15, 2014
Plumbing Forum, Professional & DIY Advice Linear drains without a traditional liner. Yesterday at 4:09 PM
Plumbing Forum, Professional & DIY Advice Water from kitchen sink drains outside when on. Yesterday at 3:07 PM
Plumbing Forum, Professional & DIY Advice New Drain lines in bathroom - does it look right? Yesterday at 11:27 AM
Plumbing Forum, Professional & DIY Advice Kitchen sink in laundry room drain size issues Tuesday at 7:08 AM
