Is this drain and vent design good to go?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by steamngn, Feb 13, 2013.
  1. steamngn
    steamngn New Member
    Feb 11, 2013
    Hudson Valley NY
    Hi all,
    I have a drain layout for my bathroom remodel, and would really appreciate input as to weather or not it is right. :p
    In the picture, the blue 3 inch main runs parallel to the floor joists, then turns with two 45's toward the toilet, which is about 24" from the second 45 in the turn. The toilet/shower area joists are boxed out, so there is good room to work. Immediately after the turn I have a 3 x 3 x 2 wye coming off to the side, with a 45 turning the 2" parallel with the toilet branch and running to the shower. This is the red line in the picture. Right after the 2" 45 I have a 2" wye facing up into the wall for the vent (green line), with the 1 1/2" lav sink drain connected to it (purple line). The shower trap wier is 5' from the vent, and the sink wier is 4' from the vent. Is this good to go? Or should I stick with my day job? :) Also, I will install a cleanout in the vent above the sink tee; how high up should this go? Is there a standard for that?
    Thanks so much for any and all feedback in advance!
    Andy
Similar Threads: drain vent
Plumbing Forum, Professional & DIY Advice Updating laundry plumbing - vent and drain pipes Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Vent/sink drain? Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Drain waste vent run new bathroom question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Polypropylene for Drain/Waste/Vent Installation Advice? Jan 4, 2017
