Is this disposal plumbed right?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by steveg91, Oct 13, 2009.
  1. steveg91
    steveg91 New Member
    Aug 14, 2006
    Hi Folks, anything wrong with this installation? Cuz it's missing the 90 coming out of the diposal, is that ok?
    Thanks, :)
    Steve
  2. jimbo
    jimbo Plumber
    Straight out is not the preferred method, but is acceptable. Your setup is NOT acceptable, because that is not a baffle tee, or at least it does not appear to be, so waste would shoot straight across. If it IS a baffle tee, then it would be OK.
  4. steveg91
    steveg91 New Member
    Aug 14, 2006
    Thanks Jimbo, it is a baffle tee. I had to check it too!
    The pipe going into the disposal is just cut off and slipped in, should it / can it be different..like a tailpiece?
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    it should have a flange and gasket on it. I don't like that set up even if it is a baffled tee.
  6. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Peter I don't remember the make but that disposal comes with a rubber boot.
    John
  7. valpohawkeye
    valpohawkeye In the Trades
    Mar 5, 2009
    Licensed Plumber
    yes, that should be a tailpiece going into the disposal.
  8. jimbo
    jimbo Plumber
    If the connection doesn't leak, I don't think I would lose sleep over it. The gasket may be squeezed just fine. As others mentioned, it is designed for a flanged tail piece, which if nothing else added mechanical strength against pull out.
  9. hj
    drain
    It probably IS a tailpiece. Not using the disposer's elbow is the good part of the drain. It is the rest of it that I do not like.
  10. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    What's that duct tape doing on there? Covering electrical connections? Not good.
  11. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I don't like center outlet wastes because they are too wobbly. I prefer the end outlet. That said, I don't see anything technically wrong with the setup. And if it doesn't wobble and come loose, bonus!
  12. hj
    duct tape
    He may be a television producer and is used to covering up any brand names or lables that have not paid for the advertising. Therefore he taped over the ISE identification. The electrical connections are on the bottom.
  13. steveg91
    steveg91 New Member
    Aug 14, 2006
    Thanks guys, it's not a tailpiece. I'll change it.
    What other type of setup would be better? Is a drawing or picture possible???
    Thanks again,
    Steve
  14. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    My house and what I typically see is like this:
    [​IMG]
    <thanks for the image SewerRatz>
Similar Threads: disposal plumbed
Plumbing Forum, Professional & DIY Advice High Wall Drain, New Sink & Disposal Dilemma Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher drain not close to sink or disposal, is this okay? (Images) Nov 28, 2016
