Is this a pressure release valve?
Discussion in 'Irrigation / Sprinkler Forum' started by craniac, May 12, 2007.
  1. craniac
    craniac New Member
    May 12, 2007
    I know nothing about sprinklers, except that our new (to us) house has them and I didn't turn them off last winter. There is water shooting out of this piece next to one of the controllers. The piece is capped off with some sort of filter, but when I turn the water on it shoots out of a 1/4" hole.
    Here is an action photo:
    http://www.writeorama.com/images/hosed/hosed.html
    It looks like it is glued on. How do I take it off and replace it? Also, am I going to electrify myself? :eek:
    Thank you very much.
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    That's an 'automatic' drain valve. It's supposed to close up, once the water pressure is applied. Buy a new one, and if that's all the damage you suffered for failing to winterize the system, then consider yourself lucky.
  4. craniac
    craniac New Member
    May 12, 2007
    Thanks! Do I just crank on it to remove it?
    It appears to be glued on. Do I just crank on it with the right wrench to remove it? Thanks!
  5. Wet_Boots
    Mar 23, 2007
    Metro NYC
    There should be 1/2 inch male threads on the device.
Similar Threads: pressure release
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
