Is there a plumbers dye?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DIYourselfer, Oct 26, 2010.
  1. DIYourselfer
    DIYourselfer New Member
    Dec 21, 2008
    New York
    Trying to find a leak in bathroom. Is there a dye that the pros use that won't stain a tub? If I use a dye in the tub water then I will know when I see the dyed water on the unfinished ceiling below that it is probably the drain, not the pipes or mixing valve.
    Thanks!!!
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Food colouring will do fine.
  4. hj
    If the leak stops, then it is NOT the pipes. There are easier ways to isolate whether it is the valve or drain, and a plumber would know how to do it.
  5. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    To check for leaks in toilets, specifically flapper valves I generally use food coloring.
    I would be hesitant to use dies in other locations.
    Michael
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I remember many years ago, the septic field police were going around to homes and flushing a packet of dye down the toilet. Then they would walk around the property looking for the dye to break to the surface or enter a stream.
  7. SacCity
    Mar 14, 2011
    Sacramento, CA
    Marina's do the same thing with boats, throw a die packet into the holding tank so they can fine anyone who pumps overboard!
  8. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
Similar Threads: plumbers
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Acrylic Tubs - Silicone vs Plumbers Putty Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Why do our plumbers suck so much? Jul 8, 2016
Plumbing Forum, Professional & DIY Advice Silicone Vs Plumbers Putty May 6, 2016
