KC SERVICES
Thank You in advance for any help
I have the original well permit. Well was set in 1990
It has a 2" X 42" Screen at 98' - 102' in "water producing sand"
Geologically the whole region is mostly sandy loam.
It had a 2 pipe adapter (1 pipe inside another) with a jet pump in a pit attached to the house.
There are problems with the two pipes coming into the pit. So I believe the adapter needs to be changed at the very least.
I suspect that the pipe assembly going down to the screen will need replacement also.
My thought was pull the whole thing and re install with fresh screen, drop pipe, adapter, and pump for a few years of service.
Then have a new larger well drilled.
So I removed the casing cap, but while removing it the casing itself was turning. (Maybe just an extension?)
Then when I got the cap off I found this three set screw deal, which is not what I expected per all the vids on utoooobe
Anyway, I made a 'T' assembly, loosed the set screws and attempted to lift the thing.
While it would jiggle and rotate, I was unable to get it to raise at all. I tapped upwards with a maul and levered the lifting, with no movement.
Does this setup need to have the pitless adapter pipes unscrewed and removed before the rest can be raised?
The well has been dormant for 2 yrs
(It is a recently acquired low end rural previous rental property)
I am trying to get some water going while I live in and restore the property.
Thank You for any help.
KC
