Is my thinking right on this upstairs washing machine?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by inexplorata, Nov 2, 2008.
  1. inexplorata
    inexplorata New Member
    Oct 22, 2008
    Colorado
    Just sort of a check for understanding. :p
    When we were first looking at this 1960's tri-level, one of the first things I noticed was the washer/dryer on the top floor. Interesting. Well, I figured, it's convenient and there is the slight possibility it was done right.
    So this week I noticed for the first time when the washer is draining, a little soapy water comes into the bathroom sink right below it, one floor down. Goes back out, too.
    Without cutting into any walls, methinks: previous owners installed washer/dryer upstairs, but probably (a) undersized the drain and (b) likely didn't vent the thing at all.
    Yeah?
  2. Terry
    Aug 17, 2004
    That could be.
    They may have run the washer into the lav vent.
    Once the walls are in, it's impossible to determine what is there.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    an easy solution. to your problem.......
    they probably installed the laundry into the
    lavatory line downstairs...below the drain line and
    are teh vent does double duty....
    most likely it is beginning to stop up and it might
    be wise to have that line cleaned....
    some day you will probably have something similar to
    "old faithful " spurting up in your sink every time
    you use the laundry and eventually its possible to have a
    substantial flood downstairs....
    get the line cleaned...
Similar Threads: thinking right
Plumbing Forum, Professional & DIY Advice Source for water tank, thinking of settling grit before pressure tank Nov 13, 2016
Plumbing Forum, Professional & DIY Advice Homeowner thinking of buying either IPC or Uniform Code book Jan 10, 2016
Plumbing Forum, Professional & DIY Advice About Plumbing: I'm thinking of becoming a plumber. Can I get some advice please? Jan 7, 2015
Plumbing Forum, Professional & DIY Advice Second Floor Pressure/Flow Problem or Maybe I'm over thinking this a bit Apr 6, 2011
Plumbing Forum, Professional & DIY Advice Sounds in drain pipes...tell me I've overthinking this Aug 24, 2009
