Is my P Drain Too Deep?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by RAMAIR, May 7, 2013.
  1. RAMAIR
    RAMAIR New Member
    May 7, 2013
    Omaha
    I have looked on the interweb here for awhile and am looking to a good answer to my question. Is this P Drain too deep going back to the outlet? I can shave off about 2 inches on the drain from the sink and the extension... as of now there are no issues/smells>?
    Thanks for your help in advance.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    No...................... It's crooked, but its not too deep
  4. RAMAIR
    RAMAIR New Member
    May 7, 2013
    Omaha
    How do I fix it? It looks like its crooked from the sink drain being un-even/
    Thanks again>
  5. Terry
    Aug 17, 2004
    I would make it shorter.
  6. Tom Sawyer
    Nov 29, 2010
    Maine
    Well its got a cheap plastic pop up assembly on it so tweaking on that can cause problems. The best thing would be to get rid of it and use a brass (chrome) pop up and tailstock assembly. I guess you can also raise it a bit but I'm not sure if you can get rid of the extension coming off the elbow out of the wall. Realistically, if it isn't leaking maybe you should just close the cabinet door and forget about it.
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If, or shall we say "when" it starts draining slowly, it will be because the trap was too deep. Shortening the sink drain, lowering the tee in the wall, or raising the vanity are a few possible solutions.
  8. jadnashua
    You should be able to shorten the tailpiece and the extension to raise it up, but if it's working, I'd probably leave it alone. The cocked tailpiece coming out of the sink may make it hard to get a good seal there.
  9. hj
    I just finished a job where there were several similar to that. If I had not used a different version, I would have had to connect all 35 that way. BUT, when I do/did them, I reversed the trap itsel without using the extension on the outlet. Your "extension" does not enter the trap far enough to prevent it from falling apart if it is bumped.
Similar Threads: Drain Deep
Plumbing Forum, Professional & DIY Advice New deep kitchen sink - disposal too low for drain? Nov 2, 2015
Plumbing Forum, Professional & DIY Advice Deep sink garbage disposal drain problems Nov 5, 2014
Plumbing Forum, Professional & DIY Advice New 10" deep sink - now waste drain too high! options? May 18, 2010
Plumbing Forum, Professional & DIY Advice How deep the drain pipe bury under the cement floor Jul 31, 2007
Plumbing Forum, Professional & DIY Advice New kitchen sink is deeper - how to hookup to drain (pics) Mar 14, 2007
