Is my Laundry room drain relocation to Code in Alberta?
Discussion in 'Canadian Plumbing Code Questions' started by supracar865, Nov 29, 2012.
  1. supracar865
    supracar865 New Member
    Nov 29, 2012
    Calgary Ab
    so just the arm is wyed backwards? everything else looks good?>
  2. Terry
    Aug 17, 2004
    Take a look at your santee on the upper re-vent.
    That needs to be turned, same as in this photo here.
    [​IMG]
  3. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I guess you missed my point on dry fitting. Your cut lengths will be too short if you measured and fitted the pipe dry.
    The black pipe you are using is NOT PVC, it is ABS!
  4. Terry
    Aug 17, 2004
    Hey, he will find that out soon enough. You can't dry fit. The pipe and fittings only slide together after the solvent has been applied to hub and pipe and then slid together with a twisting motion.
    Black DWV, ABS, and ABS glue
    White DWV, PVC and PVC glue
  5. supracar865
    Nov 29, 2012
    Calgary Ab
    Sorry Im an electrician, I guess my terminology is off. I understand that these fittings will not be fitted all the way with my dry fitting them. I dont see it being a problem other than my attachment to the existing vent, everything else has some movement to make sure its all fitted together.? I feel like im missing something here. This doesnt seem all that different from Electrical conduit pvc i run,.
    Also i did measure my cuts to the back of where they will be fully seated in the bell ends of each piece, so once glued and fully seated they should be right where they need to be
    I see what you are talking about with the upper sanitee on my re-vent, I totally missed that...makes sense though with that orientation
Similar Threads: Laundry room
Canadian Plumbing Code Questions Laundry Room Standpipe - trap required? May 6, 2011
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Laundry code req's Jul 6, 2015
Canadian Plumbing Code Questions Laundry relocate and floor drain delete fix? Jun 9, 2014
Canadian Plumbing Code Questions Laundry/Utility Sink venting in basement Jun 16, 2012
