Is my 240v line working?
Discussion in 'Electrical Forum discussion & Blog' started by Newbie2012, Jul 7, 2012.
  1. Newbie2012
    Newbie2012 New Member
    Jul 7, 2012
    Columbus, GA
    Below is a picture of my main breaker box on the side of my house. The double breaker there goes to my pool breaker box. My multimeter reads 240v when I check the red and black wires in the picture (called main breaker box).
    In main breaker box:
    Black to red is240v
    Black to ground is 120v
    Red to ground is 120v
    However when I check the red and black wires into the pool breaker box, I am only getting a reading of 120v. Shouldn't I get a reading of 240v just like the main breaker box? Reason I am asking is that my 240v pool pump and polaris pump are not working any more after an electrical storm last night . . . I have already replaced the pool pump motor with a new one . .
    In pool breaker box:
    Black to Red is 120v
    Black to white is 0v
    Red to White is 120v
    Black to ground is 0v
    White to ground is 0v
    Thanks for any help you can give me!
  2. jimbo
    jimbo Plumber
    San Diego, CA
    There is some kind of problem. Black to red should be 240.. You are good at the box and not out at the load.
    There are too many questions here....you need an electrician. We don't know why there is a white lead out there. Pure 240 loads are 2 hots and the ground, so you have some 120 going on. Don't get hurt...get help!
  4. Newbie2012
    Jul 7, 2012
    Columbus, GA
    Thanks for the quick response. (And I don't know why my pictures did not post. Probably file size is too large.)
    I will take your advice and call an electrician. I am clearly out of my comfort zone here.
  5. Newbie2012
    Jul 7, 2012
    Columbus, GA
    Mystery solved. Electrician diagnosed the problem: The black lead has apparently been cut between the main breaker box and the pool breaker box. Have rewired with new 10/3 UF wire and all is working . Now just need to bury the wire.
  6. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    Bury it deep.
  7. ballvalve
    Dec 28, 2009
    northfork, california
    As above - but most certainly in CONDUIT. Or someone will get hurt or you'll do it again.
  8. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    People want to save the cost and trouble.
    Some yellow caution tape is a very good idea.
  9. ballvalve
    Dec 28, 2009
    Yellow caution tape for your 8 year old with a hammer and stake, or shovel? Or you with a shovel? Not to mention the same gopher that got the first cable will love the second. Or maybe LA doesnt have gophers OR pumps. Conduit is about 12 cents a foot.
  10. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Don't get me wrong. I would insist on conduit.
    The burial stuff needs to go down what? 2'? I can't even remember, because I won't use it.
    If you trench to 2' and fill to 1' and then lay in the caution tape, you have a MARGINALLY safer installation. Nothing compared to conduit.
    Not sure that the OP said a gopher got it, but that is as likely as anything, I suppose.
    And no, not lots of gophers. I got bloody fruit rats which the cat insists on killing and then eating about 3/4 of the way and leaving me to eat the rest, if I want. She is so generous.
    And squirrels. Of course. The bastards just rat-copulated my apricots this year.
    Possums. Again, the possum kits get eaten.
    Raccoons. Take a pretty mean cat to go after a raccoon. Had one die in the back corner of the yard and rot for a few days. Thank the lord that the city will collect those.
    And last summer a skunk walked in the house. How do you frighten a skunk out of your house? YOU DO NOT!
    Been getting whiffs of skunk many nights of late. The cat needs to learn that no means no.
  11. ballvalve
    Dec 28, 2009
    Under the caution tape lay some junk wood or 2x4 stickers. last a long time buried 2' deep.
  12. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Even better. Pour a little concrete. On top of your plastic conduit. Nearly bullet proof.
Similar Threads: 240v line
Electrical Forum discussion & Blog 120V outlet in line to 240V heater? Mar 13, 2016
Electrical Forum discussion & Blog 240v and 2 circuits Oct 29, 2016
Electrical Forum discussion & Blog 240v breaker serving two heaters Sep 13, 2016
Electrical Forum discussion & Blog 240v circuits and using a white wire as a hot Apr 24, 2016
Electrical Forum discussion & Blog Can I plugin a 240V into a 250V receptable? Apr 19, 2016
