is liquid in tank cleaner like Ty D Bol bad for toilets?
Discussion in 'Toilet Forum discussions' started by Cameron Fields, Mar 5, 2013.
  1. Cameron Fields
    Cameron Fields Implementer/Inventor
    Mar 5, 2013
    2 year lawn , Theorist, Designer/inventor,Animator
    Florida
    I know this is probably a really dumb question but I have been asked it a lot. is liquid in tank cleaner like Ty D Bol bad for toilets?
  2. jadnashua
    Anything you install in the tank that dispenses its contents into the tank is likely not good for the rubber components. Not sure exactly what's in that, but anything that contains bleach will render the rubber components (the flapper valve, and maybe other things) into slimy crud in short order. One company makes a system that mounts in the tank, but goes in series with the bowl refill hose, and dumps it down the overflow rather than the tank. That shouldn't mess with the tank's rubber components, but will sit in the bowl until the next flush.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Every manufacturer advises against cleaners that are dispensed in tanks for the exact reason Jim explained.
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Everything they say above is true. I just looked at the TyDBowl MSDS and it looks as if it contains mostly detergent and dispersants; no mention of chlorine, which is the real bugaboo for rubber. That said, the other junk isn't likely to actually help the components even if it doesn't harm them as clearly as chlorine does.
  6. Cameron Fields
    Mar 5, 2013
    Florida
    Thanks, I won't be making that mistake again anytime soon.
  7. joemcl
    joemcl In the Trades
    Mar 2, 2013
    licensed journeyman plumber
    Pennsylvania
    If you read the paperwork that comes with the toilet it states use if in tank cleaners voids mfgr. warranty.
Similar Threads: liquid tank
Toilet Forum discussions Liquid nails for securing flange? Oct 22, 2007
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Monday at 5:17 AM
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
