Is it safe to run chlorine water into acid neutralizer from well shock treatment?
Discussion in 'Water Softener Forum, Questions and Answers' started by rob742, May 21, 2013.
  1. rob742
    rob742 New Member
    May 17, 2013
    Pennsylvania
    I am going to shock treat my well. I had the well pump replaced and my water is testing positive for coliform bacteria. I did not know if I should bypass the acid neutralizer or if it would be Ok to run it into the neutralizer?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    You are going to want to treat the acid neutralizer along with the rest of the piping or you will still have coliform bacteria running through the system
  4. Gary Slusser
    Retired
    Running some chlorinated water into the AN filter to disinfect it and then by passing it yes, running all the shock water run throughout the house through an AN filter is really bad.
Similar Threads: safe chlorine
Water Softener Forum, Questions and Answers Is Softened Water Safe to Drink? Apr 26, 2011
Water Softener Forum, Questions and Answers Wiring a pulsafeeder chemical solution pump Nov 11, 2010
Water Softener Forum, Questions and Answers Safety Valve Sticking in Closed or Up Position Oct 2, 2010
Water Softener Forum, Questions and Answers Brine Tank Safety float setting Jun 6, 2010
Water Softener Forum, Questions and Answers Katalox Light regeneration using Chlorine solution Feb 17, 2017
