is it okay to have tub faucet on exterior wall?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Nola70115, Aug 28, 2009.
  1. Nola70115
    Nola70115 New Member
    Aug 28, 2009
    Hi there -
    I'm repairing a bathroom and trying to keep the original tile walls. I'd like to reuse the old cast iron tub, which is in good shape. I've been told (by someone who is not a plumber) that it is not a good idea to do so because the tub faucet is located on an exterior wall, and it would be too difficult to make repairs later on if the faucet is not on an interior wall.
    All of the plumbing has to be reinstalled because the old lines were removed when the house's foundation was replaced. The wall is currently open below the top of the tub, because it is a 3-wall alcove style tub. I am thinking of using the kind of antique-style faucet that is mounted on the inside of the tub, so we don't have to get into the wall above the top of the tub.
    If I can reuse the old (right-hand) tub, I don't have the spend the money for a new one. If I really can't put a faucet on an exterior wall, I'll have to get a left-hand tub that won't be as nice as the antique I've got.
    Thanks for any advice!!
  2. jimbo
    jimbo Plumber
    San Diego, CA
    As far as the longevity of the faucet, we would always recommend a national brand with an good repair and parts availability reputation. Given that, the valve should last until the next remodel ( 20+ years).
    The issue of pipes in the outside wall is regarding frozen pipes, if you are in a cold climate.
  4. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    One would need to be able to get some decent insulation between the exterior wall and the fixture for a cold climate. I'm thinking some extruded polystyrene (XPS) in an appropriate thickness to fit the narrow space might provide a pretty good thermal barrier to prevent the pipe/fixture from freezing. It is moisture resistant.
    Assuming that the OP is in zip code 70115, New Orleans, LA, I doubt freezing in the wall is an issue, but I would still want some insulation between the exterior and the plumbing.
    I'm not a plumber though...
  5. hj
    faucet
    If you use a good faucet, not a Home Depot $19.95 special, there may NEVER be any need to open the wall to access it.
Similar Threads: okay faucet
Plumbing Forum, Professional & DIY Advice How much pressure can 2" DWV pipe take? Is it okay to use in pool plumbing? Jan 8, 2017
Plumbing Forum, Professional & DIY Advice Dishwasher drain not close to sink or disposal, is this okay? (Images) Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Rerouting waste line...is this radius okay? Apr 6, 2016
Plumbing Forum, Professional & DIY Advice Is it okay to offset the trap this much? Apr 2, 2016
Plumbing Forum, Professional & DIY Advice Is it okay to omit tailpiece coming from kitchen sink drain? Dec 11, 2015
