Is it ok to leave small leak alone?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by wp1, Jul 6, 2008.
  1. wp1
    wp1 New Member
    Jun 8, 2008
    HI. I have a shallow well jet pump ( 30 - 50 psi setup ). I have connected everything up very well. It is only used to water my small lawn so there is a small amount of pipe with two hose bibs on it and the pump is right next to the well hole itself. The leak occurs where the suction pipe from the well connects to a 90 degree elbow. The leak takes about 36 hours to trigger the pressure switch to turn on the pump. The pump will shut off after hitting 50 psi a few seconds later, and this will happen again in about another 36 hours. I feel that I can live with this. Will this leak eventually stop by itself? The suction pipe ( actually semi flexible tubing ) has a footvalve on it and I was wondering if I put a check valve between the 90 degree elbow and the pump if this will take the pressure off the point where it leaks now and hopefully fix the problem?
    Thanks very much for your advice in advance.
    Will.
  2. hj
    leak
    One of three things will happen, and we cannot tell you which one because it depends on many factors which cannot be predicted.
    1. The leak will remain constant.
    2. The leak will evenually cause erosion of the joint and start leaking worse.
    3. The water quality will be such that it causes the metal to corrode and stop the leak.
    None of these is really desirable and you should do whatever it takes to stop the leak NOW.
  4. wp1
    wp1 New Member
    Jun 8, 2008
    Thanks for the reply. Yeah, I figured that I will have to address the problem. I will look into what the best thing to do is. Thanks again.
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    You could have perfect plumbing, and a minute leakage through a check valve or foot valve. As long as the pressure switch is working, you are at least at a functional status.
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The suction leak should be fixed no matter what. Secondly, if the Pump comes on every 36 hours and shuts off in few seconds, you either don't have a tank or it's terribly waterlogged. You may have several problems.
    No the other Check Valve won't help. You will just lose the Prime.
    bob...
  7. Wet_Boots
    Mar 23, 2007
    Metro NYC
    I'm still thinking it isn't as critical as some flaws I encounter, not if it takes at least a day to lose pressure. And if the pump even runs for a second, I wonder if there isn't some sort of pressure tank already there. (or maybe a run of poly pipe, which has a bit of flex)
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Let's ask him what happens when he is using water. Like in the shower. Does the Pump cycle on and off or does it stay running continuously or does it eventually shut off while the shower is being used.
    bob...
Similar Threads: leave small
Pumps and Tanks Well Forum & Blog. Water is life. May I leave my lake water pressure tank out over winter? Oct 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Frozen line - OK to leave power on? Feb 21, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Leave it as is? low pressure is fixed. May 19, 2012
Pumps and Tanks Well Forum & Blog. Water is life. HELP!! How long can I leave on a utility water pump? Feb 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. How many people use CSV's and small tanks? Jun 3, 2016
