Is "dry" mold a problem?
Discussion in 'Remodel Forum & Blog' started by Macman, Mar 28, 2010.
  1. Macman
    Macman New Member
    Jan 1, 2008
    Our basement had water problems for many years. I suspect that with it going on so long, mold has to be an issue. The water problem has been solved, and the basement has been dry for about 6 months. Now I wonder if I have to worry about the mold. Will it continue to thrive in a dry basement? Will it produce spores/toxins that could be dangerous?
    If the answer to the first part of this question is "yes" then the second question would be how to best approach the problem without spending big bucks. What treatments work best? How do I know how to choose a pro who will get the job done right? If I get a pro involved, I can't spend tens of thousands of dollars. It's just not in the budget.
  2. jadnashua
    SOme mold spores can remain dormant for probably 1000's of years, and probably beyond your lifetime under some rather nasty conditions. Mold needs three things: food, moisture, and their existance to create problems. Take away any one, and it goes dormant. The least intrusive thing that kills them is probably a water/bleach solution. I'd try to rid myself of as many as possible. You'll never get rid of all of it, and new ones will be airborne to repopulate the area, but without all three legs of the triangle, it won't grow. Disoldging the spores can be a health problem; it's just when it's growing, it is producing lots, no new ones while it is dormant.
  4. TWEAK
    TWEAK New Member
    May 17, 2009
    Bay Area CA
    +1 on the bleach.
    It is probably ok as long as it stays dry. If it gets wet, mold can start to grow in 24 to 48 hours. Sometimes moist air is all that is needed.
    Check out these companies that make paint-like coatings to contain the mold: Foster, Safe Encasement Systems, and Fiberlock.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    From what I read, bleach is not a good product for mold. Get some Moldex or similar product.
Similar Threads: mold problem
Remodel Forum & Blog possible mold issue? Dec 19, 2013
Remodel Forum & Blog Mold inside exterior walls, WTF!!! Feb 26, 2013
Remodel Forum & Blog Sears moldy washer suit can proceed as a class action Nov 13, 2012
Remodel Forum & Blog Basement refinishing- how to keep mold away Feb 29, 2012
Remodel Forum & Blog Remodeling with Mold - To Live with it or Not Sep 14, 2011
