Is dielectric union necessary?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BobinChatttown, Aug 10, 2010.
  1. BobinChatttown
    BobinChatttown New Member
    Aug 10, 2010
    Chattanooga, TN
    I am transitioning from galvanized to pex. The pex fitting is brass. Do I need a dielectric union, or can I just use a simple 3/4 brass pex connector?
    I have looked at numerous forums and can find no consensus on whether a dielectric fitting is necessary when transitioning to brass.
    Thanks much for help.
  2. Terry
    Aug 17, 2004
    To transition from galvanized to PEX, you can use either a brass or a plastic fitting.
    A dielectric is used between copper and galvanized. And not always there either. If I'm plumbing in Bellevue WA, I use a 6" brass nipple between copper and galvanized.
  4. hj
    Brass and steel are compatible, Otherwise we could NOT use brass valves with steel piping.
Similar Threads: dielectric union
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Dielectric Union Application Apr 6, 2011
Plumbing Forum, Professional & DIY Advice Dielectric Union Dec 4, 2009
Plumbing Forum, Professional & DIY Advice Tank water heater- dielectric union? heat trap? Nov 23, 2008
Plumbing Forum, Professional & DIY Advice Do I need a dielectric union for my water heater? Jun 17, 2008
