Is bigger better in my overflow tank?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by jmoser, Dec 21, 2012.
  1. jmoser
    jmoser New Member
    Dec 15, 2012
    Sacramento
    I'm replacing my old 80 gal galvanized tank for my submersible pump well system. I'm thinking to buy the biggest welXtrol tank I can afford. My houselhold needs are small, with only 3 adults living in my home. But I water a little less than 2 acres using hoses s and sprinklers, which I do not run at maximum effiicency to keep my pump from cycling. I plan to intall an irrigation system in the future, and possibly irrigate most of my 5 acres, but I plan to have my well, pump etc analyzed to plan an appropriate system at that time.
    Other than spending unnecssary dollars up front on a tank bigger than I might need, what are the drawbacks to having a very large tank?
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    You may want to consider installing a Pside-kick instead of a big tank. It cost less, is smaller and will extend the life of your pump while giving you constant pressure.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Sometimes I can't help but wonder if these guys are earning a commission for posting.
    The P-side kick is fine if you want to get rid of a big tank. If you really want to go all out, a big tank AND a cycle stop valve will result in the least amount of pump cycles.
  5. jmoser
    jmoser New Member
    Dec 15, 2012
    Sacramento
    That is the plan I'm considering. I have read where cycleman recommends a smaller tank. I guess I feel like a larger tank is kind of insurance, in case for some reason the CSV is not in the system. My understanding is that an oversized tank with a csv will give lower or more variable pressure for a longer time until the tank pressure drops enough for the pump to kick in. Just wondering if this is significant enou to have concern. I guess if it didn't bother me before I wouldn't notice it much?
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    With the small tank, the pump will have to run every time you leave the sink running long enough to wash your hands or brush your teeth.
    It is always better for the pump to run continuously rather than to have it cycling. This is where the CSV makes sense.
    When I take a shower, I cannot tell any difference in the pressure between the switch's 40-60psi range.
Similar Threads: bigger better
Pumps and Tanks Well Forum & Blog Installing a Bigger Sump Pit Apr 17, 2013
Pumps and Tanks Well Forum & Blog Replacing storage tanks with bigger submersible well pumps Apr 24, 2009
Pumps and Tanks Well Forum & Blog why is a pressure tank with a bladder better than plain old steel pressure tank Mar 7, 2012
Pumps and Tanks Well Forum & Blog Back-Up Sump Pump Which is better Aug 18, 2007
