Is access necessary behind tub fixtures?
Discussion in 'Shower & Bathtub Forum & Blog' started by Jseward, Nov 18, 2004.
  1. Jseward
    Jseward New Member
    Nov 18, 2004
    Please excuse the rookie question. I'm going to remove an old tub and reinstall a new one (fiberglass). Obviously I have to remove the overflow and drain fixtures on the tub and install new ones on the new tub. My question is do I need to have access to the fixtures from the "backside" of the wall in order to accomplish this? If so, it will be a problem since I have no access to that side of the wall.
    John
  2. hj
    access
    An ecperienced plumber would not need that access, but I am not sure if you have the necessary ability to make the installation that way. Doing it without access usually only gives you one chance to do it correctly, or you have to cut everything out and start over, and you normally do not get many chances to do so before you run out of room to cut it apart.
  4. John Bridge
    John Bridge Mudmeister
    Sep 4, 2004
    Owner, John Bridge Services
    Houston, Texas
    I think you can do it with a plastic tub. You'll be able to lift the tub back out if you haven't adjusted the drain and overflow correctly. I sure wouldn't want to do it with a cast iron tub, though. :D
  5. hj
    WE do it mainly with cast iron tubs, but with careful measuring it works for any tub.
  6. Jseward
    Jseward New Member
    Nov 18, 2004
    thanks all-wish me luck-John
  7. RCraig
    RCraig Member
    Nov 20, 2004
    New Hampshire
    I know nothing but for your future sanity, it would be preferable to be able to have access. At least this is what I have found with plumbing problems over the years. Ruth
Similar Threads: access necessary
Shower & Bathtub Forum & Blog Tile an Access Panel?? Oct 20, 2016
Shower & Bathtub Forum & Blog Relocate tub in condo no access from below Jan 22, 2016
Shower & Bathtub Forum & Blog Bathtub access requirements? Jul 15, 2015
Shower & Bathtub Forum & Blog Best location for air tub access panel, front or floor? Apr 4, 2013
Shower & Bathtub Forum & Blog Preferred Makes/Models - Tileover Access Panels Apr 3, 2013
