Is a bypass humidifier a bad idea for a condensing gas furnace?
afhoke
Colorado
I have a two-stage condensing gas furnace (Payne PG9MAB I think), and I would like to install a bypass evaporative humidifier (AprilAire 400). But, given that the furnace achieves its high efficiency by condensing most of the moisture out of the air, isn't the furnace going to defeat the purpose of the humidifier?
In other words, when the furnace is blowing, some of the warm air will go through the bypass humidifier and pick up moisture. But before the moist air can get to the living space it will have to go back through the furnace, which will suck the moisture back out, right? I hope I'm wrong...
The condensing furnace is condensing the moisture in the fire side of the heat exchanger. The humidifier is only affecting the indoor-air side of the heat exchanger. Don't worry about about the humidifier moisture getting sucked back out by the furnace.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
If you feel a need to add moisture to the air, then you should explore how to stop the moisture from leaving in the first place. Chances are that if you have a leaky building envelope, that the moisture is condensing on the cold side of insulation and rotting the building.
A modern, well sealed building does not need moisture to be added but rather needs moisture to be removed.
SHort answer...it will work and not cause issues with the furnace. Whether you need one is another issue altogether. The leakier the house, the more likely you need one. FWIW, some air infiltration is good, but it is best done in a controlled manner; otherwise, the house air can get quite stale.
