Irrigation Well - Remove Rusted Seal
Discussion in 'Irrigation / Sprinkler Forum' started by Adam FL, Apr 4, 2013.
  1. Adam FL
    Adam FL New Member
    Apr 4, 2013
    Ft Myers, FL
    I just bought a house and 2 days after moving in the down pipe separated at the U-turn and for obvious reasons water is spraying everywhere and no pressure at the sprinkler heads. It appears that the piping was modified in the past improperly and there is only about 3/4" of PVC coming out of the elbow on the down pipe. I think this is why it separated since there is little surface area to cement them together.
    The seal on top of the well is rusted and I have no idea how to get it off since there are not bolt heads. Anyone have any ideas how I can get this seal open to add a new piece of PVC below the seal and fix this?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The top of the casing is too low as it is so just cut it off below the seal. Then you can use a coupling and a section of new casing to raise it up.
Similar Threads: Irrigation Remove
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum Irrigation Winterizing help Oct 27, 2016
Irrigation / Sprinkler Forum Reviving Old Irrigation System Oct 9, 2016
Irrigation / Sprinkler Forum What's best size of Irrigation pipe Aug 24, 2016
Irrigation / Sprinkler Forum Agriculture Irrigation Pipe Aug 22, 2016
