Irrigation System well set up - Myers HJ100D
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rikmoor, Apr 20, 2012.
  1. rikmoor
    rikmoor New Member
    Apr 20, 2012
    Wilmington, NC
    First the data – I live on the coast in NC. I have a 2†well that was used for potable water for years until being annexed. I am converting this to an irrigation well. The well is 98’ deep. I recently installed a new Myers HJ100D – 1Hp pump and am getting 9 GPM at 35psi from an open end garden hose. With a 5 GPM sprinkler head attached, it is pumping at 55psi.
    So this seems like a low flow to me. The pump came with a regulator installed. Can I take this regulator off? Or do I just need to back the adjustment screw all the way out for the highest flow? It also has a pressure switch. Should I take this off? Adjusting these didn’t seem to make any difference.
    I’m trying to do what I can to get close to 20GPM for my irrigation system. And I want to get the flow maximized before I do my irrigations system design.
    Thanks in advance for any help!!
  2. ballvalve
    Dec 28, 2009
    northfork, california
    lose the regulator.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Jet pumps require a regulator to hold at least 20# pressure on the system. . . I wouldn't remove the regulator! Depending on the pumping level (which will be hard to determine on a 2" well) 9 gpm at 35# is good for your pump.
  5. rikmoor
    rikmoor New Member
    Apr 20, 2012
    Wilmington, NC
    One thing I'm going to try is to remove the old pipe/packer/foot valve and replace it all. Didn't want to do this since it will be 100' of pipe but oh well. Seems to be the next logical step if I don't have something I can do on the pump itself. The well is 40 years old. No telling what condition any of that is. And my pump came with a new packer so I might as well send her down. Plus this will give me the opportunity to determine the water level in the well.
  6. ballvalve
    Dec 28, 2009
    Gotta a pile of jet pumps here and never saw anything resembleing a regulator on them.
Similar Threads: Irrigation System
Pumps and Tanks Well Forum & Blog. Water is life. Filter or screen to eliminate course sand from irrigation system Mar 1, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation system with 25 HP build Nov 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Two pumps one irrigation system Dec 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump for a small scale drip irrigation system? Aug 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Question About Pump Pressure To Irrigation System Jul 26, 2014
