I am working towards installing an irrigation system and I am starting with getting the water supply setup. I currently have two Proflo frost free bibs fed by long runs of 1/2" CPVC through a few elbows. I'll be replacing the two existing bibs with Woodford Model 19 3/4" swt, doing sweat connections now and eventually re-plumbing to PEX so i can just sweat a pex adapter and keep the bibs. I'll be changing the supply lines to 3/4" copper, re-plumbing back to where my 3/4" CPVC is and minimizing elbows and using long radius elbows where needed. I'd stick with CPVC up to the bib but I can't seem to find long 3/4" CPVC elbows. I'll also be adding ball valve shut-offs before the bib just for future service work if ever needed, alternative is shutting off my main. Finally, I'll be adding a Woodford Model 32 to supply the future irrigation system. This will also be the 3/4" swt but I will plumb it back to where I have 1" CPVC off the main and run 1" copper up to the bib and then reduce to 3/4". Does anyone have experience with the Model 32? I get static pressure at 55 PSI but I'm not sure of my max flow rate from my municipal supply, I'm just hoping it will be enough.
