Irrigation Pump Problem
Discussion in 'Irrigation / Sprinkler Forum' started by GLIINC, Aug 28, 2006.
    GLIINC New Member
    Aug 28, 2006
    I recently installed a 11 zone system with a 3/4 hsp goulds booster pump.
    When we first started the system everthing worked fine. A few days later
    we were having a problem with zones 6 and 7, the pump on these two zone would just make a sucking noise for about 8 to 10 minutes then the pump starts pushing and workes properly. All other zones in the yard work properly. The zone in question are spray zones with less gpm than most zone in the yard. We have tried several differant this to fix it with no sucess.
    We replaced the pump, pump start relay, controll box, valves on both zones, put on smaller nozzels, caped heads to make smaller zones and nothing seems to change the problem. When we first changed the pump we thought we had it fixed as its worked at first but the problem started again after a few runs.
    If anyone out ther can help it would be greatly appreciated.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What are you pulling the water from?
    You said booster pump, do you mean end suction or self priming centrifugal.
    Could this noise be the pump trying to reprime itself because of a leak back on the suction line?
Similar Threads: Irrigation Pump
Irrigation / Sprinkler Forum Timer for irrigation pump? May 13, 2016
Irrigation / Sprinkler Forum Confused about Irrigation pump shut off May 27, 2015
Irrigation / Sprinkler Forum Irrigation system on a well pump Sep 8, 2013
Irrigation / Sprinkler Forum Home irrigation pump start relay intermittent shut off issues Jul 25, 2013
Irrigation / Sprinkler Forum Irrigation pump comes on but no water Sep 7, 2010
