Irrigation layout questions
Discussion in 'Irrigation / Sprinkler Forum' started by stupid48, Nov 9, 2011.
  1. stupid48
    stupid48 New Member
    Nov 9, 2011
    NV
    I have a curbed in area that I'm going to put sod in. It is a rectangle 15 1/4 feet by 5 1/2 feet. I went into Star Nursery to get their input. The suggested installing 8 nozzles total. Four in the corners and two on each of the long sides and adjust them to about 5 feet of spray. To me that seems like overkill. Can anyone give me an idea of what they think for layout? I suppose I'll be using rainbird nozzles...
    Thanks for any advice...
    Chris
  2. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    That only adds up to 6
    My areas between sidewalk and street are the same, I use one 15SST at curb pointed back forwards sidewalk.
    4 areas, 4 heads, 60 psi, 15-20 minutes, no problem
  4. jimbo
    jimbo Plumber
    God never intended grass to be planted in 5 X 15 rectangles, so that is a difficult area to water! I agree with the nursery. To minimize sidewalk spray and runoff, put 90º 5' nozzles in each corner, and two ½(5') on each side....total of eight. That will give you coverage and minimal overspray
  5. stupid48
    stupid48 New Member
    Nov 9, 2011
    NV
    I had another recommendation of using one 15' strip nozzle in the middle of each end and one 9' strip nozzle in the middle of each long end for a total of four. That seems like a pretty good option as well..
  6. hj
    Rainbird SQ ( square) nozzles will water a 5x5, (to 6x6, depending on the pressure), square area, so three of them, properly spaced, will water the whole area with minimal "overspray".
  7. CornerWrench
    CornerWrench New Member
    Feb 15, 2012
    Irrigation and plumbing supplies online www.remote
    Montana
    Hey folks. I'm new here and irrigation was my profession so I'll probably hang out here more so than the other forums.
    Strips is what i did as well. Back when brass nozzles were readily available you could bet a 5' flat brass half and triangular space and get beautiful coverage. After they got too pricey and rare I switched to strips after experimenting with various other options. My decision was based more so on less water waste than perfect coverage. I also would advise putting that strip section on its own zone since it tends to be the hottest and driest area due to all the concrete. I found that the Irritrol ES and CS gave the widest pattern so I used those on my RB 1804s.
  8. Tbone77
    Tbone77 DIY Junior Member
    Dec 1, 2011
    San Diego, CA
    Probably the most efficient would be MP Rotators. They make side strips can reach 6x16 if you have above 40 psi. They also have left and right corner strips that are like a half a side strip that throw from either the left or right hand sides and are a much better solution than the end strips in my opinion.
  9. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Kind of an old thread so not sure the OP is still watching.
    I didn't know there were MP Rotator strip nozzles. I agree- that would be my first choice. I have replaced all the spray heads in my yard with MP Rotators. Nice to have slower water delivery, less susceptible to wind and runoff, and look purty too.
Similar Threads: Irrigation layout
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum Irrigation Winterizing help Oct 27, 2016
Irrigation / Sprinkler Forum Reviving Old Irrigation System Oct 9, 2016
Irrigation / Sprinkler Forum What's best size of Irrigation pipe Aug 24, 2016
Irrigation / Sprinkler Forum Agriculture Irrigation Pipe Aug 22, 2016
