irrigation flow rate/psi has me completely confused!
Discussion in 'Irrigation / Sprinkler Forum' started by madrone, Jan 13, 2009.
  1. madrone
    madrone New Member
    Nov 10, 2008
    Hi, I'm overwhelmed by all the calculators on the rainbird site and really need some help with some simple problems.
    Hope someone here can help.
    I'm in the process of having a well drilled and need to figure out how much water we use on irrigation, which isn't all that much.
    We run one short 100' length of 2" pipe with risers every 20' and I think 7/32 nozzles on the risers, totaling 6 risers. We move this line through the garden and yard in addition to some drip irrigation in the orchard.
    We also have some home usage on the same pump.
    How can I figure out the flow and psi we need to run this line optimally.
    Any Help, please?
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    You'd be surprised how difficult it is to quantify "some" ~ nothing prevents you from changing impact head nozzles, so you aren't locked into any particular flow. Think in terms of how much acreage you need to cover in what period of time.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If there is an irrigation supply company in your area, take a scale drawing in to them. Often these companies will design a system for you at little or no cost providing you buy all of your supplies from them. It does get complicated as it is far more than just gpm and pressure. Length of pipe needed, elevation changes, number of sprinklers on a zone, and on and on. You might even find that a complete underground and automatic system would be feasible. Even if they charge for this service, it would be a good first step.
  5. JimLewis
    JimLewis New Member
    Feb 11, 2009
    For most situations, if you installed a pump that would produce 10-20 Gallons Per Minute (GPM) and 65-100 static PSI of pressure that would be PLENTY.
Similar Threads: irrigation flow
Irrigation / Sprinkler Forum Existing irrigation system but no backflow preventer. Mar 24, 2015
Irrigation / Sprinkler Forum Newbie question, irrigation not working correctly, system off but water still flowing Oct 16, 2012
Irrigation / Sprinkler Forum Irrigation backflow Mar 20, 2010
Irrigation / Sprinkler Forum Bury drip irrigation main connected to hose bib? Mar 4, 2017
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
