iron removal
Discussion in 'Pumps and Tanks Well Forum & Blog' started by curt21, Aug 14, 2012.
  1. curt21
    curt21 New Member
    Jul 20, 2012
    Newfoundland
    Lately I've noticed rust colored staining on toilet bowk and a brownish red residue left on white clothing after wash cycle. My well water also has an odor that is earthy/metallic. I believe the issue is a high iron content. What is the easiest way to remove it: Water softener, sand filter, some type of cartridge filter or something else? A water softener is my last resort but is it the best choice? Thank you
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    While a softener can remove some iron, I don't advocate using one for iron removal. There are backwashing iron filters that do a much better job removing iron. Most work on the principle of aerating the water to oxidize the iron so that it precipitates out to be trapped by the filter media.
  4. curt21
    curt21 New Member
    Jul 20, 2012
    Newfoundland
    I have a rain fresh whole home filter in my main line - will a ceramic .3 micron filter with a carbon core (as sold by canadian tire, etc.) reduce the iron for a temporary fix?
  5. curt21
    curt21 New Member
    Jul 20, 2012
    Newfoundland
    Here is another thought/question: I've read online that chlorination can be very beneficial for iron removal, sulfur odor removal, bacteria treatment etc. Since I am running of a shallow well would it be a good idea to regularly treat the well with a certian amount of chlorine solution (the well is a metal casing 24"diameter). I dont use the water for drinking, but would the chlorine be very corrosive to the metal/galvanized casing?
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    They do make pellet feeders that drop directly into the well. From what I hear, they can corrode the casing.
    If there is a bacteria problem that is causing the smell, the chlorine should help. The chlorine will also oxidize the iron out so that it precipitates to be trapped by a filter.
    My well water looks clear when first drawn but let to sit, turns brown and develops what looks like an oily sheen. It has a noticeable smell. I aerate the water with a micronizer and then filter it with a BIRM filter. After that, it no longer has any smell.
Similar Threads: iron removal
Pumps and Tanks Well Forum & Blog Anyone run a Cuno/3M Iron removal system (Chem Free) with hydrocharger? Apr 3, 2013
Pumps and Tanks Well Forum & Blog Cleaning a filter with iron out? Dec 1, 2015
Pumps and Tanks Well Forum & Blog Installing a Chem-Free iron filter. Thoughts? Tips? Suggestions? Jul 27, 2015
Pumps and Tanks Well Forum & Blog Iron and hydrogen sulphide - is this a crazy idea? Jul 5, 2015
Pumps and Tanks Well Forum & Blog iron build up in a point driven well Jun 16, 2015
