Iron removal
Discussion in 'Water Softener Forum, Questions and Answers' started by F6Hawk, May 8, 2012.
  1. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I'm not an ex-plumber, I still hold Masters licenses in 5 states, own the business and occasionally get my hands dirty.
  2. ditttohead
    Jan 9, 2012
    Ontario California
    So, then you admit to being a "Professional"? AH HAH, I KNEW IT.
  3. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    You're right about the "how" part but you certainly did suggest that it be done.
    I suspect you left out the how part because then it can easily be challenged and refuted. I still challenge that the pipes cannot be effectively cleaned out with IO and leave it to you to prove that it can.
    ROFLMAO... How's that for the pot calling the kettle black! For the record, I don't run you down. I do criticize how you mistreat people on this forum. In this thread, I did call you out for giving bad advice and gave you the opportunity to redeem yourself. You resorted instead to denigrating others.
    Respect is something you earn. It starts with treating people with respect.
  4. Gary Slusser
    Retired
    Actually I said: "I'd get some Iron Out etc. into the plumbing to the softener or the fixtures to clean out the rust build up. I'd replace any plumbing to the softener that was less than 3/4". I'd run some IO through the softener then too.". I did not tell him to do it or that he should do it. And he replied that he didn't think it would work, along with Andy, Steve and YOU.
    Well the how of it couldn't be challenged and disputed unless someone did exactly as I said to do it and then it didn't work. You have said you did it and it didn't work so you continue to say it can't work although I didn't tell you how to do it and you haven't said how you did it or for how long. duh!! And below you now say I'm supposed to prove to you that it works. LOL
    I treat people as they treat me. Other than you saying IO won't work, I don't see where you've said I've given bad advice in this thread.
    In other threads I have given you advice about your water treatment equipment that doesn't work very well and how to correct it and you've disagreed with everything I've told you. As you have about rust in a pipe and the use of IO in this thread, simply because it didn't work for you! Frankly I don't think you tired it.
    Disagreeing simply because you think something won't work, or because you tired it without knowing how to do it and it didn't work, is not being respectful IMO.
  5. Tom Sawyer
    Nov 29, 2010
    Maine
    That's your post so "I'd get some iron out into the plumbing to the softener" which implies that you would somehow isolate the run from the tank to the valve, introduce Iron out and that would get rid of the iron. We are all telling you that if there is a large build up of iron, you could soak it for a month and not clear it out and further, you would have to bypass the piping so the customer would have water in the house.
    " I did not tell him to do it or that he should do it" What in hell does that mean? If you are not recommending that he should do it then why bother saying anything at all?
    This whole mess should be pretty much wrapped up. Game, set, match.....
  6. Gary Slusser
    Retired
    There ya go again posting something you didn't say but making it look as if you did...
    IMO, based on past experience with him, he wasn't going to listen to anything I recommended, suggested or told him to do so I told him what I would do but I didn't tell him how I'd do it so others reading this now or in the future know there is something that can be done if they have the same problem instead of probably listening to someone telling them to replace all the plumbing.
    BTW, I learned through trial and error how to get rust build up out of galvanized pipe so as to be able to sanitize/disinfect the plumbing to get rid of Coliform bacteria for VA and FHA mortgages. Then I got into well rehabilitation to get rid of rust build up in water lines from the pump to the pressure tank. And people actually paid me to do it based on the results and yer good buddy Liggy is it, he says it won't work. LOL little does he know and he sure as hell doesn't know what he doesn't know. WOW, that applies to you too.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    Nice try but I don't think anybody's buying it LOL
Similar Threads: Iron removal
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Sunday at 12:24 PM
Water Softener Forum, Questions and Answers Sulfate and Iron removal Nov 2, 2016
Water Softener Forum, Questions and Answers Iron removal Jul 25, 2016
Water Softener Forum, Questions and Answers Iron Breaker III vs KDF 85 for Iron removal Dec 31, 2015
Water Softener Forum, Questions and Answers Irrigation Well Iron removal system recommendations ***UPDATE*** Sep 10, 2015
